Good evening guys.
Aaron sorry to hear that you are having problems with the stang.
I have been doing some reading about your truck and you might have some trouble with your injectors and your cold starts.
A lot of guys have had good luck with the Rev-X oil additive.
i see that, i also see there is a huge debate thread about rev-x for big $$$ versus the zddp for minimal $$$. i may try it. it is at the bottom of my list now though, because the truck runs fine after 5 minutes of warmup time so its not a big issue. yet...
F U justin
that just happened with my uncles 04 6.0. he had to get 3 injectors replaced and it runs better than ever he says.
good morning CT. i dont need to be up yet but i cannot stop coughing.
andy i dont think that guys truck has the same issue, although i wouldnt rule it out. my truck still fires right up when its cold, it just will run like it has a big cam in it.
