Just installed my DP Tuner... ANNNNNDDD...
Old 10-31-2010, 05:44 PM
FTrucker's Avatar
FTrucker
FTrucker is offline
Originally Posted by Nkelly
Setting 2 my be 1300 or 1400 rpm setting,what does it do when you are in park or neutral then put it on 2 with out touching the throttle ??.
In park, the motor just revs way up at first, and if I'm on the brake as I said it jumps forward!
Sorry If I hijacked your thread bud!!
john
Old 10-31-2010, 05:48 PM
FTrucker's Avatar
FTrucker
FTrucker is offline
Yeah my tuner is a blast!
Old 10-31-2010, 05:58 PM
Nkelly's Avatar
Nkelly
Nkelly is offline
Farkall User
Ahh righto,if she goes back down to low idle after reving up,might be a problem that needs fixing .
Old 10-31-2010, 06:01 PM
AmericanMade's Avatar
AmericanMade
AmericanMade is offline
And I was trying to take the tuner off but I dont know how it's supposed to come off, Ive gone all directions and it sure is on there, wonder if it was glued, cause I see some signs of some kinda adhesive.
john
No worries about hi-jacking my threat... we're all here to learn (although general rule of thumb is that when looking for answers it's best to start your own thread)
But unless you can get in contact with the previous owner in regards to what tunes you have on the chip, I would pull the chip and then send it to Jody at DP Tuner (cost you like $5 with the priority flat rate box) Just give him a call first and let him know what you want to do (his number is on their website: dp-tuner.com)
Pulling the PCM is the easiest thing on this truck to do (in my opinion)... takes like 5 minutes. I used this video when putting mine in, so just reverse when you want to take it out (more or less but you'll figure it out)
Link to movie
Good luck!
Old 10-31-2010, 06:08 PM
joeyd61's Avatar
joeyd61
joeyd61 is offline
with the no start.. i have to turn truck off, turn key back on (do not start) press both buttons til i get "0" trrn truck off.. and then it will not start...
Old 10-31-2010, 06:22 PM
FTrucker's Avatar
FTrucker
FTrucker is offline
Thanks for the advice!
Again thanks American Made! And congrats on the tuner!
john
Old 10-31-2010, 06:27 PM
overthehillbill's Avatar
overthehillbill
overthehillbill is offline
Sorry guys....
Old 10-31-2010, 06:44 PM
joeyd61's Avatar
joeyd61
joeyd61 is offline
Originally Posted by overthehillbill
I have the F-5 and just press both buttons, it will go to 0 then the 0 will blink rapidly and I turn the key to off. Before I start I turn the key to on hold the negetive button until the 1 (stock) setting appears and it will start right up.
That is correct... one way to check it is after the 0 blinks rapidly and you turn the key off...turn the key back on, it shouldnt show any number until youpush and hold the minus button (3 seconds i think)
Old 10-31-2010, 07:03 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
You just gave it away to everyone who can google........
Old 10-31-2010, 07:09 PM
Bob Taulbee's Avatar
Bob Taulbee
Bob Taulbee is offline
Duct Tape Tech.
He can go back and edit the post, then it won't show up if someone did do a search. I think that is how it works.
Old 10-31-2010, 07:20 PM
FTrucker's Avatar
FTrucker
FTrucker is offline
Stinkin Google!
Sorry for all the trouble.
john
Old 10-31-2010, 07:32 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
No prob, thats just something that should be kept secret.
  #28
Old 10-31-2010, 08:19 PM
Bob Taulbee
Duct Tape Tech.
Stinkin Google!
john
John, you can go back to the post about the No-start procedures and just edit the part about how to turn off the no-start, and all will be good
  #29
Old 10-31-2010, 08:48 PM
TreySmith's Avatar
TreySmith
TreySmith is offline
Originally Posted by AmericanMade
Throttle pedal is a little touchy, but I knew that going in. I'm just glad its not as bad as I thought! I had fears that it was going to be as sensitive as the god-awful new cars with EXTREMELY touchy throttles... You know those ones... They tend to also have those brakes where you barely touch the brake pedal and the car slams your face into the steering wheel.... I hate cars
Haha, I have done that before. I work at a body shop so I am in and out of cars all day, lets say some cars are more touchy than others. The worst are the 90's chevy trucks that don't have any brake response until the pedal hits the floor. First time that happened I nearly **** myself.
1L243
11-03-2016 07:08 PM
darknight
53
09-01-2015 09:05 AM
ImConfused666
20
01-31-2013 04:18 PM
bublitz3
03-19-2012 05:34 PM
MHammer21
33
05-25-2011 05:21 PM
Quick Reply: Just installed my DP Tuner... ANNNNNDDD...
