ICP - What does it do?
Old Oct 27, 2010 | 01:58 PM
southern79's Avatar
southern79
When I did my 15.6k mod yesterday, I noticed my ICP sensor was soaking wet. I am assuming it is bad. The truck runs and starts great! Do I need to replace this sensor, and what changes can I expect?
Thanks-
Robert
Old Oct 27, 2010 | 02:15 PM
427 fordman's Avatar
427 fordman
wet with oil? You need to replace it then. IIRC, the icp sends signal to the pcm, then the pcm sends that to the ipr. The pcm could be sending a default setting to the ipr if the icp is bad. It probably runs the same unplugged as it does plugged in?
cutlass
28
Jan 4, 2014 11:07 AM
rangerbob406
Jan 19, 2013 08:14 PM
robert421960
Aug 5, 2012 05:18 AM
tholt34
Mar 6, 2007 07:15 PM
Robert6401
15
Sep 30, 2005 09:57 PM
