Rough idol after engine cleaning - SOLVED!
Old Oct 30, 2010 | 07:57 AM
ospreyguy's Avatar
ospreyguy
Originally Posted by Greyf100
was any major "scrubbing" done at the distributor? Check your timing, if the dizzy is loose the initial timing may have moved.
Nope no scrubbing but it gets worse...
Last night was a disaster!
So it was running rough but was still drivable. I took it to my dad's and changed the dist cap and rotor. Once that was done it was missing horribly and could barely run. we trouble shooted the firing order even making adjustments to the dist and timing. NOTHING!
After 3 hours we gave up and I decided to take it to a local mechanic who has experience with these...
I know it is going to be some stupid little thing but after working 60 hours a week and coming home to the wife and 2 little girls I just don't have the energy to fight with it every night.
The only thing we haven't checked is the compression (I doubt there is an issue there but who the F knows at this point.) mainly because we didn't have a tester...
Old Oct 31, 2010 | 10:54 AM
65superduty's Avatar
65superduty
good copy. i know what you mean. i have been chasin a stumbling off the line for several months with my old dodge and just got sick of taking all my free time with that. i took it to a hot rod guy and he found the problem after a bit. timing chain stretched not enough to jump but the crank was spinning 15 degrees before the cam moved and with throttle it moved around like a politician at election time, couldn't make up it's mind...
it'll be something with electrical, my guess. let us know what it was, would like to keep that in the mental notes. best of good fortune to you.
fool4trucks
Old Oct 31, 2010 | 01:27 PM
ospreyguy's Avatar
ospreyguy
fool4trucks
Thanks for the encouragement...
Old Oct 31, 2010 | 08:17 PM
Greyf100's Avatar
Greyf100
make sure you put the wires on the cap going counter clockwise....i set the correct firing order but in a clockwise direction on a Mustang and it ran but ran like S*&T.
Old Nov 1, 2010 | 07:36 AM
ospreyguy's Avatar
ospreyguy
Oh yeah, went through that... We actually got so frustrated that we thought when the engine was rebuilt about 40K ago they may have put the dist. on off one tooth off, so we went and moved the wires each direction with no luck.
I dropped it off Saturday night at the shop and just talked to the mechanic. He's getting ready to pull it in the shop and it going...
Ho hum...
Old Nov 3, 2010 | 06:07 AM
ospreyguy's Avatar
ospreyguy
SOLVED!
Alright so apparently when I cleaned the engine this threw off the timing. Which doesn't make a whole lot of sense but whatever. When I replaced the dist cap and rotor I used the firing order that I thought I should 1-5-4-2-6-3-7-8. Apparently when the engine was rebuild they used the cam out of the 351 or it is an HO, which I now think it is, and should have used 1-3-7-2-6-5-4-8.
As you can imagine it ran like total donkey *****.
And since we thought it was right no wonder we couldn't figure it out.
Anyway. The guy fixed it up corrected the timing and only charged $40! Which I would have paid in the beginning of this whole mess. Really nice guy to, which is always a plus.
I need to learn how to adjust the timing using a light...
Thanks for all the help! I had to take a little ribbing from the Napa guys (my father in law owns the store and recommended the mechanic) but boy was it worth it to not have to worry and fight with it while getting to learn something new!
Old Nov 3, 2010 | 09:40 AM
65superduty
i did not see that one coming!! glad you got it fixed. good mental note for me too. ask about engine history...
cheers
Old Nov 3, 2010 | 05:10 PM
Fordzilla80's Avatar
Fordzilla80
Glad you got her fixed!
Old Nov 4, 2010 | 07:03 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
They changed the firing order for the 302 sometime in the 90's (1995?) to 1-3-7-2-6-5-4-8.
So what you say makes total sence. Shows the engines been worked on in the past.
I would not have guessed that in a million years either. Kudos to the mechanic.
Old Nov 5, 2010 | 07:57 AM
ospreyguy's Avatar
ospreyguy
Exactly what I said!
basstardo
Jun 3, 2017 09:58 PM
maytea
May 7, 2017 02:19 PM
ChristopherN
May 27, 2011 08:10 AM
Doc
22
Aug 2, 2010 09:52 PM
RUSTANG67
Mar 3, 2007 02:13 PM
