Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Pressure Washers
Old 10-26-2010, 06:19 PM
mantta's Avatar
mantta
mantta is offline
Pressure Washers
I'm looking to buy a gas powered pressure washer and would like to hear from pressure washer owners on what is good and what to stay away from. Thanks!
Old 10-26-2010, 06:26 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Stay away from any light duty vertical drive pressure washers. They are junk and just one step up from electric. What will you be using it for? The 3 units I have I built and work great I bought all the engines from harbor freight and bought 3 pumps off ebay like this http://cgi.ebay.com/PRESSURE-WASHER-...#ht_1787wt_657 I used to like the CAT brand pumps but they are not very good anymore and have been wowed on the ANNOVI REVERBERI pumps great service life easy oil changes and parts are easy to get.
Old 10-26-2010, 06:31 PM
mantta's Avatar
mantta
mantta is offline
I will be using it for general purpose and degreasing my backhoe.
Old 10-26-2010, 10:44 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
Rental stores sometimes sell their equipment, that stuff is typically 10x better than what you'll find at the big box stores.
Old 12-29-2010, 12:03 AM
Gevans17's Avatar
Gevans17
Gevans17 is offline
pressure washers
Get one with a CAT pump...allpressurewashers.com
Old 01-10-2011, 05:49 AM
Talltruck's Avatar
Talltruck
Talltruck is offline
I was able to get a deal on one that somebody had ran the pump dry on. It still developed pressure but you could tell it wasn't right. It's a CAT pump, the seal kit was SHOCKINGKY expensive for it just being a small handful of o rings and washers, but it was simple to rebuild and works really good now. Apparently you can burn up the seals from just starting it without water hooked to the pump, so be forewarned.
Old 01-28-2011, 12:48 AM
Chaosracing's Avatar
Chaosracing
Chaosracing is offline
I have a Excell (Devilbiss) 2600 psi one and really like it. It came with different tips for different angles. I have used to clean many different things and never had a problem with it.
Old 01-31-2011, 08:27 AM
UnionHauler690's Avatar
UnionHauler690
UnionHauler690 is offline
Why buy new??????
pawn shops......many commercial units are stolen off work sites and end-up at the pawn shops.....
BKSMN
11-09-2015 04:46 PM
Piolet
03-26-2015 08:28 PM
johnmel59
01-15-2014 10:59 PM
Myfreeford
01-04-2012 06:22 PM
nickalbu
1997-2006 Expedition & Navigator
03-14-2005 10:34 AM
Quick Reply: Pressure Washers
