Replacing Parking Brake Cable
Old Oct 26, 2010 | 05:27 PM
KillerTux's Avatar
KillerTux
This is for my 1959 F100 and the front parking brake cable is frozen. What is the proper way to remove the cable and replace? I can't figure it out
Old Oct 26, 2010 | 11:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Bump to top -- surely one of the fridge guys can help. You might try dribbling penetrating oil down from the top, see if you can free it up.
Old Oct 27, 2010 | 12:30 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
The parking brake cable is actually 2 cables.One from the handle to a "yoke" another from the yoke to each rear wheel.You should be able to disconnect at the yoke,which would release the pressure so you can disconnect at the handle assembly.From there remove it so you can inspect, clean, and lube the handle assembly.
Do you have the correct manual for your truck?That should be every old truck owners first purchase.That,and AAA Plus coverage.Seriously,I changed mine about 5 years ago, the rear one, more recently.I would consider changing front and rear cables.Good luck, and buy a manual for the shop,and one on disc for the desktop.
Old Oct 27, 2010 | 04:27 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 1957/63 Ford Truck Parts Catalog is available on a CD from hipoparts.com.
C0TZ2A635A .. Rear Parking Brake Cable / Obsolete
Fits: 1957/60 F100 2WD & 1957/59 F250 2WD / I found 4 of these NOS.
There are two different front parking brake cables:
B9TT2853K .. Front Parking Brake Cable / 80 1/2" long / Obsolete
Fits: 1957/60 F100 w/a 110" wheelbase / I found 23 of these NOS.
B9TT2853L .. Front Parking Brake Cable / 88 1/2" long / Obsolete
Fits: 1957/60 F100 w/a 118" wheelbase / 1957/59 F250 / I found 9 of these NOS.
Old Oct 27, 2010 | 10:00 PM
KillerTux's Avatar
KillerTux
I was able to cut the cable and remove it except from the handle. How do I remove the ball end of the cable from the handle? Other then that, I almost got this thing going.
Old Oct 28, 2010 | 02:41 AM
Julies Cool F1's Avatar
Julies Cool F1
Some folks have been successful by using a small nuclear device!
Old Aug 13, 2011 | 01:38 AM
Alta59 F-250's Avatar
Alta59 F-250
Replacing parking brake cablr
You need to remove the press fit. We did it fairly quickly by putting the press fit head in a vice and turning it until loose. Now I have to figure out how to put the spring back below the anchor bracket! Any ideas?
Old Aug 13, 2011 | 04:09 PM
Alta59 F-250
Parking brake
figured it out. Low IQ is an issue with me.
Old Aug 13, 2011 | 04:16 PM
ibuzzard's Avatar
ibuzzard
I wrote that book.
Old Aug 13, 2011 | 11:01 PM
WALFORD'S 56's Avatar
WALFORD'S 56
FOR SURE!!!!!!!!!!! LOL
Necco-2
17
Dec 2, 2019 04:06 PM
pamante
Jun 10, 2019 12:26 PM
blueoval65
Mar 3, 2017 01:30 PM
curtis88
Feb 13, 2014 09:45 AM
Stroker 94 1/2
Aug 3, 2011 10:02 AM
