Turbo choice
Old Oct 26, 2010 | 01:55 AM
zoommx's Avatar
zoommx
Turbo choice
First of all a little history on my truck: Early 04-I got it used with about 70k on it. Now has about 95k. I took it in for diagnosis as it was running poorly. They say the turbo needs rebuilt or replaced, about $1600 or so. One of the other items they found was the wrong coolant is in it. Apparently p.o. put the green stuff in. I added coolant earlier this year, but put the motorcraft premium gold in, not knowing there was the green coolant in system. Could it just be the wrong coolant got the turbo sticky and just needs cleaned? If it really does need replaced, what are good options at similar prices? I'm not interested in making more power necessarily, but would welcome greater reliability.
Thanks!
Old Oct 26, 2010 | 02:20 AM
dchamberlain's Avatar
dchamberlain
There is no coolant to the turbo, so that is not related. You do need to properly flush and refill with the right coolant, however.
https://www.ford-trucks.com/forums/9...nge-101-a.html
There is a thread that contains links to how to clean the turbo, and International and Ford part numbers for the cleaning kit.
https://www.ford-trucks.com/forums/8...urbo-abcs.html
Old Oct 26, 2010 | 04:29 AM
Nice Work Truck's Avatar
Nice Work Truck
I just put in the new Garrett Powermax and love it.
You can get them for about $1,200-1,300.
Old Oct 26, 2010 | 08:26 AM
zoommx's Avatar
zoommx
Thanks for the infos. Is the Garrett much different than the stock Garrett that it came with ?
Old Oct 26, 2010 | 09:18 AM
npccpartsman's Avatar
npccpartsman
It's a direct bolt-on. It's a little bigger on compressor and exhaust side but you don't have to change intake tubes or exhaust to put it on.
Old Oct 26, 2010 | 09:19 AM
tex25025's Avatar
tex25025
I think the powermax is a direct replacement for the stock turbo. I don't think you even have to get a custom tune for it either.
Old Oct 26, 2010 | 09:28 AM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE zoommx Make sure you read through the Tech Folder located at the top of this forum.
Old Oct 26, 2010 | 09:31 AM
cartmanea's Avatar
cartmanea
You don't HAVE TO get a custom tune, but it will help. The PowerMax is quite a bit larger than the stock, so you have more lag without tuning.
Old Oct 26, 2010 | 09:50 AM
tex25025's Avatar
tex25025
I never looked at the specs on it, so I wasn't sure about that. I just know that it was a direct bolt on. But then again, mine is a direct bolt on and I had to have custom tuning otherwise there would have been a big "dead spot" with it.
Old Oct 26, 2010 | 09:58 AM
cartmanea's Avatar
cartmanea
I ran with no tune with my PowerMax for a while and it was fine. There was a dead spot around 45mph when the TC is locked, but that's still there with the tune, just not as bad. The PowerMax is 63.7mm and Eric at Innovative told me the stock turbo is 58mm, he said it's more of a race turbo than a towing turbo. It has very good driveability for being a larger VGT turbo.
Old Oct 26, 2010 | 10:49 AM
Sarge261's Avatar
Sarge261
So how does it perform while towing...or can Eric correct that with a tune. I would love a power max, but I tow often and dont want to sacrifice andy workability of my truck.
Sarge
Old Oct 26, 2010 | 10:53 AM
WH 6.0's Avatar
WH 6.0
Not meaning to hijack but what are the advantages of the Powermax supposed to be over the stock turbo? What about disadvantages (other then the "dead spot" we've already heard about?)
Old Oct 26, 2010 | 11:11 AM
woodlander's Avatar
woodlander
If I had to replace turbo, I would be interested in one that you dont' have to be cleaning all the time. Are these all variable vane?
Old Oct 27, 2010 | 05:26 PM
shinyconcrete's Avatar
shinyconcrete
Also interested in benefits?
Old Oct 27, 2010 | 06:59 PM
smokersteve's Avatar
smokersteve
slightly slower spool up
lower egts
some more power
This has all the information that is available
powermax turbo 6.0 - Google Search
I got these links from the google above
http://thedieselgarage.com/forums/sh...d.php?t=100735
http://www.powerstroke.org/forum/6-0...-question.html
http://www.thedieselstop.com/forums/...3-07-a-259470/
Super Duty Service
Jan 30, 2015 07:31 PM
texasfd
6.4L Power Stroke Diesel
Sep 23, 2011 02:28 PM
ordy1
Dec 22, 2006 08:38 PM
Phil Schroder
Dec 14, 2006 08:26 PM
Starratt04
Mar 20, 2003 03:31 AM
