Front Leaf Springs
Old Oct 25, 2010 | 08:53 PM
stephen.south's Avatar
stephen.south
Front Leaf Springs
Currently I have some sort of Ford spring on the front of my truck that provides an approximate 4" lift. Does anyone know what truck these came out of.
Second I'm planning to drop my truck back down to stock height with stock tires in hopes of a better ride and better mileage. I know a junk yard nearby that I can get leafs at about $25 each, but I think all they have is from Gas burner 250's and 350's. So my question is are they the same as is in a diesel truck?
And as soon as i swap out the springs and wheels they'll be for sell by the way.
Old Oct 25, 2010 | 09:20 PM
Midwest Dually's Avatar
Midwest Dually
As for the springs on the gassers and diesels being the same, no. The gassers will sag after seeing some road time under a diesel.
As for the springs you have that are lifted.. Umm.. No idea.. Any pics you can toss on to help would be great!
Old Oct 25, 2010 | 09:27 PM
stephen.south
does anyone here by chance have some stock springs they are willing to part with or trade for mine?
Old Oct 25, 2010 | 09:35 PM
Krisx125's Avatar
Krisx125
Id be curious...I have a set id trade...Post some pics.
Old Oct 26, 2010 | 05:56 AM
tjbeggs's Avatar
tjbeggs
The springs you have on now are probably from a F-Superduty (f-450). When put on the 250/350 they provide about 4 inches of lift.
Old Oct 26, 2010 | 04:21 PM
Brain's 97 Diesel's Avatar
Brain's 97 Diesel
I was going to guess F-350 spring w/ the solid axel Dana 60 swap that's on tfront of your rig. I'm also going to guess that you did not perform the swap since you don't know where the axel or springs came from. I thought that on the SAS the axel & spring raise it 4 in.
Old Oct 26, 2010 | 04:30 PM
tjbeggs's Avatar
tjbeggs
That could also be true. I didn't pay any attention to if OP had a 250 or 350
Old Oct 26, 2010 | 04:35 PM
stephen.south
Here's some pics to help in identification (click to enlarge)
Old Oct 26, 2010 | 04:40 PM
stephen.south
No I did the axle swap. The leafs were already there with the TTB axle. The axle swap only raised the front about an inch. The axle I bought for $550 but the springs were on it when I bought the truck.
Old Oct 26, 2010 | 05:00 PM
tjbeggs's Avatar
tjbeggs
There is an extra leaf in that spring pack from stock. So you could remove usually the bottom leaf and drop about 1.5 inches. Also the 250 springs are thicker than the 350 springs so you might get a better ride if you get F-350 diesel springs. I can't say that for sure though.
Old Oct 26, 2010 | 06:00 PM
Brain's 97 Diesel
My stock F-250 Diesel TTB springs are 2 full leaves w/ EW117 97 and F5TAWA stamped near the ft eye w/ fomoco logo, the brace that wraps the spring has EWB2 and 1367 stamped on it. The SAS swap parts I have set aside are from an 80's F-350 (gas I think) has only 2 full leaves also w/ a diff set of characters on it. Your springs look like it has 3 full leaves so I'd have to agree it's prob an F-450 or up especially since it looks like your springs also have the fomoco logo. Dumb ? has anyone also changed the front piviot/shackel w/ a longer one?
NotMatt
Sep 19, 2016 07:30 PM
Alec Blanchard
May 12, 2016 10:25 AM
Outlaw56
Sep 5, 2013 02:41 PM
yelosub79
May 24, 2011 10:22 AM
jad4
Jun 14, 2005 09:42 PM
