Ignition Switch Replacement
Old Oct 25, 2010 | 02:57 PM
thekingofcows's Avatar
thekingofcows
I bought a 78 f150 not too terribly long ago, and the truck had been sitting in the same spot for 9 years, the PO did not have the keys, is there a sneaky way to get the ignition tumbler out with out a key? Or is picking the lock or replacing the whole switch the only answer. Thanks
Old Oct 25, 2010 | 03:21 PM
tinaheels's Avatar
tinaheels
could remove the whole assembly an take it to a locksmith
Old Oct 25, 2010 | 05:20 PM
steponit's Avatar
steponit
Due to the design, you have to have a key to remove the whole assembly.
Old Oct 25, 2010 | 05:49 PM
jim collins's Avatar
jim collins
Can you hot wire it and drive it to a lock smith ?
Or use a body panel dent remover to pop the cylinder out ?
Once the cylinder is out , you can remove the retainer ring and remove the switch. Throw it away and replace the complete unit. P.S save the retainer ring to reuse as the new one won't have one.
Old Oct 25, 2010 | 08:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You can remove the entire switch without removing the inner tumbler.
An older locksmith or a Ford dealer that's been arounda while might have some master keys to get the tumbler out, or make you set of new keys. Just take the ignition switch and one of the door locks with out.
Josh
Old Oct 27, 2010 | 07:15 AM
jim collins
Josh
I was using the information that ' STEPONIT ' provided and made some alternative suggestions to do it .I DID SAY TAKE IT TO A LOCKSMITH. But there is allways somebody that that can't make a suggestion unless they point out that somebody else may be wrong.
Old Oct 27, 2010 | 01:30 PM
steponit's Avatar
steponit
On a 78 the bezel/collar screws on to the switch and without first removing the tumbler, it won't come off.
unforunately the locksmith has to come to the switch,not the other way around
Try gathering up all the Ford keys you can find, one of them may work in the lock
http://www.autozone.com/autozone/rep...00c1528004bb07
Old Oct 27, 2010 | 03:37 PM
jim collins
I changed mine out about 2 weeks ago and did it like the autozone instructions show. I was replacing the complete unit as it had a short in it and wanted the use the key and matching locks from another parts truck so I would only need the one key. I never saw any other way to remove it with out doing damage other than poping the cylinder if the key was missing. Those are good instructions. JIM
Old Oct 29, 2010 | 12:17 AM
thekingofcows
Problem has been resolved, though I tried about 45 ford keys, none worked. So I just grabbed two ignitions from a junkyard.
Old Oct 29, 2010 | 08:19 AM
jim collins
I hope it works out okay, I'm allways a little concerned about using junkyard electrical anything. A new complete unit is only about $25.00 or $30.00 , less chance in getting an electrical short ,fire maybe. Good luck .
the gruffalo
Jan 8, 2022 07:38 PM
fordman19762003
2009 - 2014 F150
Aug 7, 2017 11:58 AM
Spam46
Feb 18, 2017 11:51 AM
bigcrunch
Large Truck
May 8, 2016 11:52 AM
calmer82
1997 - 2003 F150
Jul 10, 2014 09:37 PM
