What have you done to your truck today?
  #19321
Old 12-23-2019, 10:53 AM
Deadsquiggles's Avatar
Deadsquiggles
Deadsquiggles is offline
Chased all the threaded holes on my GT40 heads and received my non tilt column in the mail. Hopefully get that swapped out this afternoon. Shouldn’t take more than a couple hours, right?
Edit: Got the steering column swapped out
  #19322
Old 12-23-2019, 05:46 PM
rhythim's Avatar
rhythim
rhythim is offline
Santa came a little early and made it a little easier to work on the truck.
  #19323
Old 12-25-2019, 04:36 PM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,172 Likes on 1,844 Posts
Marry X-Mass everyone
My family was here earlier in the week so today was just the wife and I so spent an hour or 2 in the garage.
The rear tank sender stopped working shortly after I get it on the road so I worked on that toady.
Know what it's like to drop the rear tank even empty?
I checked to make sure the wiring was good by shorting out the wires so knew it was the new sender.
Once out I knew what it was, the float was full of gas.
I did test the sender and it works great.
Swapped float from the old sender, drop unit back in tank and tank back up in place.
I hope it dose not leak once I have fuel in the tank.
Dave ----
  #19324
Old 12-25-2019, 08:09 PM
mckenziedg's Avatar
mckenziedg
mckenziedg is offline
Finally got my 38 gallon fuel tank installed, primed the fuel system and now running on two tanks.
Also put in and wired a 7-pin trailer plug.
  #19325
Old 12-26-2019, 10:31 AM
Mason_811's Avatar
Mason_811
Mason_811 is offline
Not today, but last night is close enough
Ended up getting some new cab lights for christmas, since I had been wanting to install some since I bought the truck. Went with some that are unconventional, doesn't have a replaceable bulb, just has the LEDs made into the light housing. I know I know, but they were cheap and they'll do for now. Just need silicone for the gaskets since the housings don't sit perfectly flush on the roof. Managed to line them up right and the spacing is good.
  #19326
Old 12-26-2019, 02:18 PM
greyghost85's Avatar
greyghost85
greyghost85 is offline
Installed shift *****, and reattached accelerator pedal
  #19327
Old 12-31-2019, 01:58 PM
FuzzFace2's Avatar
FuzzFace2
Took the truck to work for the last time this year. Truck runs great but I am not happy how fast the 16 gallon gas tank gauge moves off full.
Gauge was over full when I left and it is about 60 miles round trip, it is now on half a tank. You can watch it drop as you drive.
The first MPG reading I got on the truck was around 12 MPG, not bad but not great for a straight six.
Last Sunday I installed the head light relay harness and gave a few turns on the head light adjusters to raise them some as they were to low for my liking.
Because I left at 2am, read still dark out, I was able to "test" the head lights and got to say they work pretty good on low and crazy bright!
Anyone thinking of doing the head light relay harness DON'T THINK just do it.
Dave ----
  #19328
Old 12-31-2019, 04:14 PM
Old Hickory's Avatar
Old Hickory
Old Hickory is offline
Glad you got the truck going. I'm like you I don't like the small gas tank.
I'm running a 351W with a 3.70 rear and a AOD trans. It gets about 11 to
12 around town. That's about all I use it for. I also have the headlight relays
and they work great.
  #19329
Old 12-31-2019, 09:07 PM
Big-Dawg's Avatar
Big-Dawg
Big-Dawg is offline
Headlight relay harness
Dave ----
FuzzFace2 is this what you’re talking about? This is from LMCTruck.com. I’ve been wanting to upgrade to LED’s but not thrilled with the price and especially the performance of them. Thanks!
  #19330
Old 12-31-2019, 10:02 PM
FordFETruck's Avatar
FordFETruck
FordFETruck is offline
I did the headlight relay about 4 or 5 years back and I've been very happy with it. I also installed one on my grand marquis and it made a big difference on that vehicle as well. Unfortunately I do 80% of my driving at night.
as far as you guys getting 11 to 12 mpg around town. You could be getting 9.5 to 10.5 mpg city like I do. Id be thrilled to get 11-12 city. The hills and stop and go just drain those tanks. Good thing I dont hammer the miles on it like I used to, save quite a bit of gas with the big merc.
Then loads like this really suck gas lol.
  #19331
Old 01-01-2020, 04:28 AM
FuzzFace2's Avatar
FuzzFace2
Yes that's the one but mine had this bright yellow covers not the black like that one.
That was one of the reasons why it took so long for me to install it, did not want this yellow showing!
I was lucky as I was able to hide the yellow behind the radiator & battery.
If for some reason the harness stops working I can just unplug it and plug the trucks harness back in and have lights again.
Dave ----
  #19332
Old 01-01-2020, 04:36 AM
FuzzFace2's Avatar
FuzzFace2
I bet them rear springs were crying! LOL
My MPG is with a little 300 six and a T18, only thing is I do have a 19 gallon rear tank I added so between station stops is greater.
When the small tank is empty I can get a better MPG reading as I have been only using it as I had to fix the rear tanks sender.
I will fill both and run numbers again but might by a while as the weather may turn bad and will not be driving the truck muchthen.
Dave ----
  #19333
Old 01-01-2020, 04:04 PM
FordFETruck
Dave ----
That was the first time I've ever had enough weight to have the bump stops resting on the axle. I've done 2 yards of topsoil in the past but this stuff was wet. LOTS of extra weight. Good thing it was only a 2 mile drive lol. Drove like a fish. I have dual 19 gallon tanks and I usually fill both full, switch tanks at about 150 miles and usually have 4-5 gallons remaining in each tank. I thought I got crappy MPG until my sister with her Tahoe that's only a few years old told me she barely gets 12 mpg with it. OD trans, lockup converter, fuel injection, and only 12? Screw that. I guess my MPG isn't terrible for what it is. Cost of ownership and insurance is so cheap I could care less anyways.
  #19334
Old 01-03-2020, 05:20 PM
Old Hickory
I put new outside window felt stripes on my truck today. Once I figured out how to get the old ones off
it was easy to fit the new ones. And they really helped the seal on the widows. I got mine from
LMC Truck and they fit fine. The inner ones are still good so I didn't replace them.
  #19335
Old 02-21-2020, 08:20 PM
kr98664's Avatar
kr98664
kr98664 is online now
Replaced the battery recently. Finally got around around to an old trick I was taught years ago. Drive a small sheet metal screw into the top of each battery post. This makes a handy place to clip your meter test leads and will save you a lot of grief:
Quick Reply: What have you done to your truck today?
