Help please
Old Oct 22, 2010 | 09:10 PM
hillybilly678's Avatar
hillybilly678
Unhappy Help please
i'm haveing problems starting my 94 f series truck the glow plug light only stays on for like 2 seconds at the most and the solenoid does click if someone could help me out it would be very appreciated
thanks
nate
Old Oct 22, 2010 | 09:38 PM
skyfox10's Avatar
skyfox10
I don't know much about diesels, so I have very little to go on. Do glow plugs have a specified resistance range? Can you check to verify the resistance is in spec?
Did the light stay on longer and only recently started going off very soon?
Old Oct 22, 2010 | 09:47 PM
hillybilly678
it just started recently even after it has been running for a good time and i shut the truck off and leave it for an hour or so and it takes a really long time to get it going....and i'm not sure i just got the truck about a year ago for the spec's of the plugs
g_k50's Avatar
g_k50
Did this just start or has the problem gotten worse?
Did it take two or three tries to get it started before it finally quit?
How old's the battery(s)?
Old Oct 22, 2010 | 09:50 PM
skyfox10's Avatar
skyfox10
so are you saying that the truck is hard to start even when it's warm, or are you saying the truck is hard to start even though it's not super cold?
Old Oct 22, 2010 | 10:02 PM
hillybilly678
batteries are not even 6 months old and it takes like 7 or 8 trys weather the truck is warm or cold
Old Oct 22, 2010 | 10:08 PM
skyfox10's Avatar
skyfox10
hard start might not be related to the glow plug system. It might have another problem. an old boss had a 94 the the 7.3 and he always had problems with either injectors or injector wiring (can't remember) and this made it a real pain in the *** to start.
If the glow plugs are not remaining on as they normally do, then it's in that system somewhere. I would determine how the truck determines how long to run the plugs for.
...and unfortunately, we have reached the end of my knowledge of diesel glow plugs. gonna have to wait for a real diesel guy to get on here.
Old Oct 22, 2010 | 10:16 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
Might try asking on the diesel board. There's a TON of good help there... not saying this is the wrong place just saying you might get help faster there then here.
Old Oct 22, 2010 | 10:17 PM
hillybilly678
well thank you for your help, you gave me a bit more to think about then starting off and buying glow pluggs and a new solenoid, and it not work for me
mars2424
Dec 20, 2014 07:38 PM
heartnurse73
Apr 14, 2013 09:45 PM
sadmama
2004 - 2008 F150
23
Jan 23, 2012 10:03 AM
buzzard
Mar 13, 2002 11:52 AM
leftlane
Feb 9, 2002 03:24 PM
