mama needs help
Old Jan 15, 2012 | 02:54 PM
sadmama's Avatar
sadmama
mama needs help
My son has a 06 f150 what is another name for idle air filter ? I am trying to help but he is at his wits end about this truck...so ay help about this part would be helpful. thanks
Old Jan 15, 2012 | 03:13 PM
MCDavis's Avatar
MCDavis
Idle air filter? To my knowledge there isn't such item.
there is a general air filter. What problems are your son experiencing with his truck?
Old Jan 15, 2012 | 03:21 PM
sadmama's Avatar
sadmama
Idle air control value is the name that the guy that looked at it said it was. The problem is that it doesn't idle...gasps like for air.
Old Jan 15, 2012 | 03:25 PM
MCDavis's Avatar
MCDavis
What engine is in your son's truck? The 5.4l does not have an idle air control valve like previous trucks/engines. It does however have a throttle body (located behind and under the air filer housing) that could be dirty and not functioning properly.
But again...do you know which engine?
Old Jan 15, 2012 | 03:26 PM
hydro_37's Avatar
hydro_37
the IAC is located inside the air intake tube and can be cleaned. Wipe it off with a q-tip and CRC cleaner very carefully. It is a thin looking wire inside the plastci tubing
Old Jan 15, 2012 | 03:28 PM
MCDavis's Avatar
MCDavis
That would be the mass air flow sensor you are speaking of. Also known as MAF.
Old Jan 15, 2012 | 03:36 PM
sadmama's Avatar
sadmama
4.6 engine
Old Jan 15, 2012 | 03:44 PM
MCDavis's Avatar
MCDavis
4.6l also does not have an IAC. The drive by wire system uses computer input to actuate the throttle body. Its likely that the throttle body needs to be cleaned on your sons truck.
Old Jan 15, 2012 | 03:47 PM
sadmama's Avatar
sadmama
we will give it a try...thanks so much you have been most helpful . I will let you know the outsome.
Old Jan 15, 2012 | 03:50 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE sadmama The gentlemen here will help you out and get your son back up and running.
MCDavis's Avatar
MCDavis
Sounds good. And good luck. Run a search on here for tips on how to clean. Do not use carb cleaner as it is too harsh.
By the way...welcome to FTE!
Old Jan 15, 2012 | 04:00 PM
critterf1's Avatar
critterf1
"CEL" on? Any codes present?
Old Jan 15, 2012 | 04:08 PM
sadmama's Avatar
sadmama
no codes...everything on hold until tomorrow when temps get above zero...right now it is minus 7 time to quit for the day. LOL
Old Jan 15, 2012 | 06:57 PM
hydro_37's Avatar
hydro_37
sorry I miss-typed the correct part name mama....but do clean the MAF and also dis-connect the neg battery cable for 10 mins. That re-sets the computer.
Old Jan 16, 2012 | 08:00 AM
60DRB's Avatar
60DRB
sadmama, as a parent myself... I hope you are introducing him to the idea of using these forums as well as how to perform the work himself...
