pertronix ignition help
Old Mar 11, 2002 | 09:25 AM
buzzard's Avatar
buzzard
Old Mar 11, 2002 | 06:39 PM
Ford Trucks Rule's Avatar
Ford Trucks Rule
i ordered the pertronix setup for my 68 f100 and have not recieved it yet. I did not order the flamethrower coil, it is 40,000 volts. Ihave a coil that is 65,000 volts (an ultra coil) Well the ultra coil is not the type you bolt to the block its the type you screw in the inner fender. Well the wires on the pertronix setup are only about 1 foot long, so it wont reach that long. instead of cutting them... which a dealer of pertronix said it would void the warrenty... i thought i might just bolt the coil to the power stearring braket thing... right by the distributor.. any of you have any other suggestions? Thanks
John 68 f100 360FE power
Old Mar 11, 2002 | 08:38 PM
Sunny_in_hollister's Avatar
Sunny_in_hollister
Do you have AC? If not find the AC braket that bolts to the head on the drivers side and mount the coil on top of it. It is a nice flat surface to mount things on.
Reggie
Old Mar 13, 2002 | 11:52 AM
Ford Trucks Rule
the air cleaner is sorda in the way. i think im just gunna jimmy it up to the powersteering bracket somehow. any other suggestions?
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
