Augh!!!!
Old Nov 5, 2010 | 07:16 PM
  #61
sncbluegt's Avatar
sncbluegt
Originally Posted by Sgt93
I'm saying the tolerances are TIGHT period. Probably both companies to blame. There is not any wiggle room on that hitch. I believe the holes on the receiver (possible powder coat) OR the pins on the hitch are too tight. I will work on the truck more this weekend (maybe some WD40 in the pins to slide? Dremel?) and post results.
There is definately a problem somewhere because everything I've put into that tube doesn't fit without me having to modify something. IMO I would not use wd40 in those pins.....maybe use some graphite lubrication powder or some silicon spray...to keep from atrracting too much dust in the pins. Granted its gonna get dust in it because its outside but I'm just thinking to minimize the dust and keep it from creating a dust clump inside of it.
Old Nov 5, 2010 | 07:21 PM
  #62
Sgt93's Avatar
Sgt93
I may take a sledge hammer to this son of a gun before too long!!!
Old Nov 5, 2010 | 07:24 PM
  #63
porthole's Avatar
porthole
I have a 2" DT hitch and when it was new I also had some trouble with the pins. Didn't take long though for it fit "just nice"
Old Nov 5, 2010 | 07:26 PM
  #64
Sgt93's Avatar
Sgt93
What did you do to make the pins fit?
Old Nov 5, 2010 | 07:43 PM
  #65
porthole's Avatar
porthole
IIRC I think I used a rat tail file in the receiver, just to clean out the paint. Then it was just miles after that.
I needed an 8" drop for my motorcycle trailer, so now I am using an Alumastinger with a stainless steel quick pin.
Old Nov 7, 2010 | 02:07 PM
  #66
Sgt93's Avatar
Sgt93
FINAL UPDATE
I had to take a Dremel to the pin holes. Either the pins are slightly high or the holes are slightly low on the receiver. After a few moments of grinding, the hitch fits like a charm and looks like something that should be on the back of these fine rigs. Would I buy a DT hitch for the 3rd time...you betcha
Old Nov 7, 2010 | 03:27 PM
  #67
kper05's Avatar
kper05
You need to hurry and get that hitch broken in; it's too shiny! Haha.
Old Nov 7, 2010 | 03:29 PM
  #68
Sgt93's Avatar
Sgt93
I forgot how shiny they are brand new! Kinda nice lol
Old Nov 10, 2010 | 01:21 PM
  #69
Sgt93's Avatar
Sgt93
And I now have two 2.5" 6" drop DT's!!!
Old Nov 12, 2010 | 05:04 PM
  #70
2addy's Avatar
2addy
Returned from a week long trip and there was my box from DT, all perched and waiting to be installed. For even better news, mine slipped right in and I didn't have to mess with it at all. I believe the tolerances are a bit sloppy on the Ford hitches as a lot of people had had some issues with adapters and what not so I was happy to have no issues. And like Sgt93's photos above, it is a true work of art.
Old Nov 12, 2010 | 05:26 PM
  #71
Sgt93's Avatar
Sgt93
And like I posted earlier, I have a second one for sale if there is interest in it, shoot me a PM. I'm Sgt93 on eBay with 100% poss feedback as well.
Old Nov 12, 2010 | 06:00 PM
  #72
porthole's Avatar
porthole
From etrailer- comments on the Ford 2.5 receiver.
Titan Reducer Sleeve 2-1/2" to 2" Draw-Tite Hitch Accessories 58102
Note: Ford OEM hitches have a tighter/different radius on their 2-1/2 inch receiver tubes. To accommodate the OEM Ford 2-1/2 inch hitch, the corners of a ball mount, shank or reducer sleeve may need to be sanded down to slide into the hitch. Do not remove any more material than necessary. Simply removing the paint or powder-coat is often sufficient.
Old Nov 12, 2010 | 07:58 PM
  #73
2addy's Avatar
2addy
And now we know. I wonder if DT was made aware of this and did some re-engineering on their hitches; it took forever to ship but it did fit perfectly. The adapter sleeve edges were rounded out quite nicely but then again, for the costs of these hitches, the quality does need to be top notch.
Old Nov 12, 2010 | 08:01 PM
  #74
Sgt93's Avatar
Sgt93
Yes DT knows. DT said Ford has released several bulletins on the hitch issues. It took me a few seconds to make it fit right. No biggie. The hitches are amazing and I still have a new in box one. Thanks for all the PM's.
Old Nov 12, 2010 | 09:06 PM
  #75
AlexWV's Avatar
AlexWV
I have the Titan reducer. The only material I had to remove was the sticker on the side of it. Then it slid right in. Before that it was being ornery. I put a dab of grease on all 4 sides when I use it just in case it decides it doesn't want to come out again.
