I hate things that rattle...
Old Oct 22, 2010 | 05:13 PM
kper05's Avatar
kper05
I tested the console rattle today.
It seems it wouldn't matter if I sealed the lid better, it's the latch/handle that rattles.
(Although sealing it better would put additional pressure on the latch possibly preventing a rattle.)
I can have it unlatched (holding onto the lid) and hit it carefully with my fist and it rattles. It only does this on screwed up roads and I slow down for the bad spots I'm familar with anyways so it doesn't rattle most of the time. When it does, everything else rattling almost drowns it out (stuff in door pocket).
Old Oct 22, 2010 | 05:37 PM
srkr's Avatar
srkr
Ok, So I'm not the only one. I'm gonna have it fixed next week. Or at least tell my service writer and see what he recommends.
Shane
Old Oct 22, 2010 | 06:48 PM
Tacswa3's Avatar
Tacswa3
I got a rattle some where in the driver's door. It almost sounds as if the door is rubbing on something. I only hear it on gravels roads and bumps. I'm hoping when I get around to doing the door seal mod it will fix it.
I also had the same sound expect it was really pronounced when I had two passengers in the back of the cab. I'm always trying to figure out what it is but no luck.
Old Oct 22, 2010 | 07:22 PM
srkr's Avatar
srkr
I have pin pointed it down, i KNOW EXACTLY WHAT IT IS. It's the latch itself. The little l shaped latch that hooks the lid shut. Very loose.
Shane
Old Oct 23, 2010 | 02:29 PM
kper05's Avatar
kper05
Shane
You are correct.
Old Nov 5, 2010 | 03:23 PM
srkr's Avatar
srkr
Ford replaced the arm Rest,...Quiet as a church mouse now!!!
Shane
Old Nov 6, 2010 | 12:11 AM
kper05's Avatar
kper05
Shane
Interesting. I may mention this next time I'm there.
Does that plastic latch move at all now when you have the lid open and push on it?
I have a rattle in my dash now, too (no, not the engine).
I think it's behind the radio unit and hitting the dash doesn't stop it.
Depending on the RPM's, I can hear it over the engine (which isn't difficult since I can hardly hear that thing) and with the radio on a few notches.
I'm going to have to track that one down before I go crazy.
Old Nov 6, 2010 | 04:28 PM
srkr's Avatar
srkr
When the lid is open, the first latch itself was loose. Just the hook. You could flick it and it was majorly loose. Now The latch,hook,is solid. Almost no wiggle at all. Not the pull latch but the catch itself.
Shane
Old Nov 6, 2010 | 07:11 PM
kper05's Avatar
kper05
Shane
Correct, not the outside handle but that white latch that holds the lid down.
Mine must not rattle as much as yours did but it shouldn't be moving as much as it is unsupported.
I'll have them replace it anyways since it's obviously not supposed to do that.
sagmill
Oct 23, 2017 09:41 AM
LiquidSteam
Jul 4, 2017 01:55 PM
Z06PSI
Aug 18, 2015 05:44 PM
greggara
6.7L Power Stroke Diesel
Mar 22, 2011 06:48 PM
calzone
1978 - 1996 Big Bronco
23
Aug 30, 2006 11:20 AM
