Question: Upfitter Switches ?
Old Nov 6, 2010 | 11:56 AM
sandyc's Avatar
sandyc
I'm no electrical guru, so be patient please. When hooking up one of the switches (example rear RV camera) I have a red (hot) wire and green (ground). Do I just wire-in the hot to one of the switch wires (probably the 10 amp one violet/green) and connect the ground wherever I can find a good connection for ground, like a screw or bolt in the metal? Is that all their is to it? Thanks
Old Nov 6, 2010 | 12:16 PM
720Deere's Avatar
720Deere
Yep that's all there is to it.
Old Nov 6, 2010 | 12:43 PM
kper05's Avatar
kper05
Here is a picture where I know the upfitter fuse box grounds to.
It is accessable from the drivers side behind the dash.
If you have the flow through console, I think slightly lower than the cup holder area.
Old Nov 6, 2010 | 04:33 PM
Jcbuch's Avatar
Jcbuch
it? Thanks
What camera did you get?
Old Nov 6, 2010 | 08:49 PM
sandyc's Avatar
sandyc
jcbuch, Not sure the name, but it has always worked pretty good for the past couple of years. Now that I have a new truck I'm re-installing it. Has a 7" screen and the camera is mounted on the back of my 5vr RV and everything is hard wired.
coleboy11
1983 - 2012 Ranger & B-Series
Jan 27, 2014 09:07 AM
jlj6t
15
Apr 10, 2011 05:02 PM
zitman11
Mar 21, 2010 03:16 PM
caseys
15
Mar 11, 2007 11:02 PM
ford55truck
Oct 28, 2004 11:20 PM
