Power steering head replacement
Old Oct 18, 2010 | 10:13 AM
fslay's Avatar
fslay
What's involved in replacing a power steering head (i think that's what it's called)? mine's pouring ps fluid and im not sure how's best to remove it.
Old Oct 18, 2010 | 10:15 AM
jmikeyj4's Avatar
jmikeyj4
un doing a couple bolts the one going to the engine and the one attached to the bracket and unplug the hose
Old Oct 18, 2010 | 10:18 AM
fslay's Avatar
fslay
ok thanks. guess i was making it harder than it is.
Old Oct 18, 2010 | 10:33 AM
jmikeyj4's Avatar
jmikeyj4
yeah but if your taking the pulley off you need a special tool
Old Oct 18, 2010 | 02:16 PM
bkaul's Avatar
bkaul
Are you talking about the gearbox or the pump?
Old Oct 19, 2010 | 11:39 AM
fslay's Avatar
fslay
talking about the power steering gear box. heavy cast iron thing that connects to steering shaft.
Old Oct 19, 2010 | 11:57 AM
Blown 331's Avatar
Blown 331
Do you have a little more info on the truck? F-150/250? 2wd/4wd? It makes a difference. Either way, the ones I have done were pretty straight forward, not bad at all.
Another option. Where is it leaking? Mine was leaking BAD out of the seal where the steering shaft hooks up. I bought the seal for $6 at O'Reilly and it was easy to replace. This was probably 4 years ago and it has been fine ever since.
KW75F150
Jan 30, 2020 01:10 AM
Joco
Jun 13, 2014 02:04 PM
rews2
Jun 3, 2014 11:57 AM
JoeR09
May 26, 2012 06:59 PM
Arfur
Apr 16, 2006 07:21 PM
