IDM upgrade
Old Oct 17, 2010 | 12:44 PM
derek0525's Avatar
derek0525
IDM upgrade
Is an upgraded IDM worth it with a chip and what actually does it do?
Old Oct 17, 2010 | 02:43 PM
megawatt00's Avatar
megawatt00
I think that you are referring to the IDM mod which just adds a resistor to the IDM to increase the voltage. The higher voltage makes the injectors open a bit quicker. I personally dont think that it is necessary with a chip or tuner
Old Oct 17, 2010 | 03:22 PM
derek0525's Avatar
derek0525
Kinda like what this is
Old Oct 17, 2010 | 03:25 PM
derek0525's Avatar
derek0525
Beans Diesel Performance - 7.3 Power Stroke IDM Modification (Powered by CubeCart)
Old Oct 17, 2010 | 03:34 PM
PaysonPSD's Avatar
PaysonPSD
Custom tunes can be had that will be just as good whether you have a 110, 120 or modified voltage IDM. If you are going to get tunes don't bother with modified IDM. Or if you are not going to get tunes you can modify the IDM yourself for a couple of bucks. See this IDM Mod Pictorial by Scott (Cookie).
Old Oct 17, 2010 | 04:06 PM
Diesel 724's Avatar
Diesel 724
Does it have the same effects or is it in the same field as doing a 10K mod or higher resistance?
Old Oct 17, 2010 | 06:49 PM
PaysonPSD's Avatar
PaysonPSD
The 10k mod fools the PCM into increasing the ICP by sending a lower ICP sensor signal which increases fueling. You could build an adjustable 10k mod with the proper rheostat.
The IDM mod effects the SOI (Start Of Injection) timing.
Old Oct 17, 2010 | 07:42 PM
derek0525's Avatar
derek0525
Alright I already have tunes so I will scratch that one off the list thanks
Old Oct 17, 2010 | 07:53 PM
PaysonPSD's Avatar
PaysonPSD
Good idea Derek. It could mess with your tunes.
Old Oct 17, 2010 | 10:45 PM
Diesel 724's Avatar
Diesel 724
Say someone dosent have tunes now, so they 140 the IDM, then down the road tunes come along. Would having a 140 be a problem, can it be changed back to stock or is it a one time deal and would prevent you from getting tunes later?
Old Oct 18, 2010 | 12:20 AM
PaysonPSD's Avatar
PaysonPSD
I would just make sure that whoever is supplying the tunes is made aware of the 140 IDM. It may make a difference in their tuning.
tiopet
21
Apr 11, 2014 05:44 PM
damicofuel
15
Jan 17, 2010 01:57 PM
hfugate
Nov 24, 2009 12:04 PM
RubberDuck
19
Apr 30, 2007 07:02 PM
lblevins12
1983 - 2012 Ranger & B-Series
Jun 26, 2003 12:01 PM
