power window wiring problem
Old Oct 16, 2010 | 03:28 PM
73pwrstrk's Avatar
73pwrstrk
my 1997 f-350 passenger window goes down but not up and the drivers master control wont control the passenger side at all , the switches are good and all thes have the right powers and grounds until you hit the switch then theres power going where ground should be im lost any one have any ideas???
Old Oct 16, 2010 | 03:54 PM
Midwest Dually's Avatar
Midwest Dually
Sounds like a bad regulator on the passenger side. I would say check the ground wire connections, but there arent any. The wiring is completely coupled into connectors, up to the main harness. You could check to make sure the passenger door is grounded well, in that you dont have a lot of solvents on the hinges, but thats as far as that will go.
Old Oct 16, 2010 | 04:34 PM
Action4478's Avatar
Action4478
I'd look for a broken wire in the drivers door bundle between the door & the pillar...
Old Oct 16, 2010 | 06:19 PM
chicagodragon's Avatar
chicagodragon
the power is going to the ground because the switch reverses the polarity to make the motor change directions. i would swap the switch,if it is only working in one direction you know the motor is good
Old Oct 16, 2010 | 06:30 PM
Action4478's Avatar
Action4478
Old Oct 16, 2010 | 06:38 PM
chicagodragon
teamlx88
Feb 2, 2014 03:34 PM
jenkinsj
Electrical Systems/Wiring
Mar 10, 2013 08:14 PM
fod
Jun 7, 2011 01:12 PM
Mish
1997 - 2003 F150
Feb 24, 2010 07:36 PM
markvii91
Mar 13, 2008 07:30 PM
