1978 - 1996 Big Bronco
glass pack help
Old Oct 14, 2010 | 10:15 PM
JERSEY MUD's Avatar
JERSEY MUD
Exclamation glass pack help
well i in stalled a thrush glass pack 32"/ 2 1/2 sounds great untill i go 30mph + then it hisses cant find any exaust leaks any advice will be greatly appreciated
Old Oct 14, 2010 | 11:06 PM
g_k50's Avatar
g_k50
Any advice?
Really?
Old Oct 15, 2010 | 10:56 AM
JERSEY MUD's Avatar
JERSEY MUD
found the leak welded everything and it still hisses i losing my mind
Old Oct 15, 2010 | 11:05 AM
cOpE!'s Avatar
cOpE!
I bet your running 2" tubing. You can read my opinion on glasspacks on the aftermarket parts forum. I say scrap them, go up to 2.5" from the manifold into a dual in dual out magnaflow/borla/flowmaster ect. and 3" out. That "hissing" sound at high RPMs is the most disgusting sound EVER! When I bought my bronco it had 2" pipe from front to rear, out the stock exit with dual 32" glasspacks. I was embarassed to drive it for the sound.
Old Oct 15, 2010 | 11:09 AM
cOpE!'s Avatar
cOpE!
I personaly dont care for glasspacks. I have used them on chevys, dodges, and fords. The only good set up I had them on was a 77 chev malibu. 305 with long tube headers and cherry bombs on 3 in pipes that exited before the rear wheel. I also had them (for a short time) on a 98 Dakota RT. They sounded ok and were 2.5 in pipes front to rear with a cat. I dumped the cat, put a magnaflow single in/out in its place and turned the pipe out the side, it was 3 times louder, and had a ton more power. Now on to my bronco, when I bought it some clown put 2" pipes, front to rear on it with 32" glasspacks about half way down, no cats, 351w. It sounded like complete garbage above 2500 rmp. I bumped to 2.5" from the manifold to the dual in dual out magnaflow (which also acts as an xpipe because of the way it is built) and 3" out. I went from being scared to pull out in traffic to smoking my 33's on dry pavement. I know alot of guys are fond of glasspacks, but the technology has since improved dramaticaly. IF..IF IF IF, I were to ever HAVE to use glasspacks again, I would make sure they were behind a good set of headers, no cats, and there was an x or h pipe. Id use large diameter pipe and dump them short of the rear of the vehicle. Magnaflow all the way for me.
cOpE!'s Avatar
cOpE!
There...I copy and pasted for you!
Old Oct 15, 2010 | 11:20 AM
JERSEY MUD's Avatar
JERSEY MUD
2 cats glass pack is 6" from cat the the i have 4 foot of 2 1/2" and it still sound like s#)T
ford1977owner
Oct 11, 2011 04:56 PM
mrsteveo19761982
1997 - 2003 F150
Mar 5, 2007 08:31 PM
RyanMiller
Exhaust Systems
Jan 10, 2005 06:52 PM
superman0604
Jun 4, 2004 12:30 AM
phantom22
Exhaust Systems
Mar 26, 2004 08:22 AM
