BW 1345 & 1356 t-case whats the diffrence?
This is what I found on several sites doing a google search. Is the differance that the 1356 is electric shift?
BORG-WARNER 1345
Type: Chain-driven, aluminum
Low-range ratio: 2.72:1
Lubricant: ATF
Length: (in.): 17.25
Width (in.): 23.0
Height: (in.): 12.0
Used by: Some 1980-to-88 full-size Fords. Holds six pints of Dextron II ATF. This unit can be towed extended distances
because of its built-in pump that channels oil to all necessary bearings
BORG-WARNER 1356
Type: Chain-driven, magnesium case
Used by: Recent-model Heavy-Duty Fords; replaced B-W model 1345.
BORG-WARNER 1345
Lubricant: ATF
Width (in.): 23.0
Height: (in.): 12.0
BORG-WARNER 1356
blucollar4xford
35
01-27-2012 10:25 PM
rartbob
06-07-2011 03:50 PM
desperado10
02-07-2008 02:44 PM
richep
03-21-2007 12:19 PM
oldhalftons
07-11-2004 06:00 PM
