Spindle Nuts and Washer
Old Oct 13, 2010 | 08:18 PM
Victor L's Avatar
Victor L
69 F100 4x4 Dana 44.
Was tightening the locking spindle nut, and the washer that is sandwiched between the two spindle nuts spun. The tang that is supposed to stay in the groove in the spindle ran up on the spindle threads and jammed.
I disassembled, and checked by putting the first nut, then the keyed washer, then the locking/jam nut on the spindle without the hub, drum and bearing assembly, and it torqued fine.
Reassembled with the hub and drum, and the washer spun on the spindle threads again. It appears that the threads on the spindle are a little buggered right at that point.
Does anybody have any experience in dealing with this issue?
Old Oct 14, 2010 | 02:35 AM
RustyShackelford's Avatar
RustyShackelford
can you use a newer style nuts and washer?
Old Oct 14, 2010 | 07:41 AM
GreenDinosaur's Avatar
GreenDinosaur
I bought 2 of these for my 70 f100 and never looked back Ford Bronco Front Axle Spindle 1967-72 Dana 30 & 44: eBay Motors (item 360133989287 end time Oct-15-10 15:48:08 PDT)
spindles from broncos up to 72 will work if you are still running drum brakes
Old Oct 14, 2010 | 09:14 AM
Victor L's Avatar
Victor L
By newer style, what do you mean ?
I found OEM replacements that look identical, that is, if Bronco Dana 44, and F100 Dana 44 is the same.
Old Oct 14, 2010 | 09:18 AM
Victor L's Avatar
Victor L
Thanks for that information. It is easier to find Bronco parts, and wonder if they interchange.
Old Oct 14, 2010 | 04:55 PM
GreenDinosaur
my truck has spindles and steering box from a bronco, so yes they will.
tseekins
General Automotive Discussion
Aug 28, 2019 10:02 AM
F-WhiteThunder
Jan 5, 2016 11:30 AM
ericconn
Oct 21, 2013 02:28 PM
ErrorS
1978 - 1996 Big Bronco
Feb 5, 2012 03:16 PM
Krisx125
18
Dec 12, 2010 04:18 PM
