bolt size for harmonic balancer puller
Old Oct 13, 2010 | 10:23 AM
deadbishop12's Avatar
deadbishop12
Rented gear puller bolts don't fit the threads in the harmonic balancer. 5/16 is too small and 3/8 is too big. Same with 8 mm. Haven't found anything in between.
Old Oct 13, 2010 | 01:00 PM
parr4's Avatar
parr4
asked same question and was told they are 3/8-16x4". man crawled under his ride and tested size.
Old Oct 13, 2010 | 01:13 PM
deadbishop12
I finally got a 3 jaw gear puller and that worked. 3/8 was too big.
Old Oct 13, 2010 | 07:04 PM
Ford_Six's Avatar
Ford_Six
3/8" should have worked. You probably have years of built up gunk that is preventing the bolts from fitting.
A three jaw puller is generally not recommended, since the pulley can be easily damaged.
wfo1955
Mar 6, 2016 02:19 AM
AZ1977
Modular V8 (4.6L, 5.4L)
Nov 16, 2015 01:43 PM
merkswitch
1983 - 2012 Ranger & B-Series
Nov 2, 2015 06:19 PM
Bagbyknoter
Nov 24, 2011 02:38 AM
WillFargo
Mar 18, 2011 03:17 PM
