I am finally ready to replace the door and window seals on my 66. I bought the gasket that goes around the gas filler neck, from that "Lousy Motor Company" Truck place. It's been on the truck for less than a year, and it's already cracked and it's dry rotted so bad it leaves black chalk on my hand when I touch it. I refuse to buy anything else from them, and I don't want to buy something else just as junky form another company.
Who do you guys suggest for good quality window/door seals?
Reason: Clarification
Suggest have them throw in a catalog, believe with purchase catalog is free, they have an article on installation which is also in their online catalog. Found the vent seal kit cut the wind noise quite a bit but installing can be a bear, went to local hardware and purchased additional rivets and a small pre cut piece of square aluminum stock, or something simular, to insert inside channel in order to set the rivet.
