Change timing gears
Old Oct 11, 2010 | 06:13 PM
deadbishop12's Avatar
deadbishop12
Change timing gears
The distributor doesn't turn on my 96, assume its timing gears. Don't see valves moving through oil filler opening. Can we be sure its the gears? How big a job is this with right tools?
Old Oct 11, 2010 | 09:41 PM
overlandexpress's Avatar
overlandexpress
This may be a simple fix, If your distributor shaft is not turning then the pin that holds the gear on the bottom of the distributor shaft probably sheared, you can pull the distributor and get a new roll pin or buy a new distributor, Napa sells the roll pin for a couple bucks and with the proper punch you just knock out the old broken pin and lightly hammer in the new one, as for not seeing the rockers going up and down that could lead to a much more serious problem. sometimes when the gears shear or a timing chain break's and the valves are in the open position they will destroy the pistons on the up stroke. please provide more info such as did you just try to start it up and it wouldn't start or were you driving it and it just died?
Old Oct 12, 2010 | 07:17 AM
deadbishop12
A friend was driving it and it just quit. It has 145,715 miles on it. It doesn't sound bad turning over just doesn't fire. We thought either no fuel or electrical problem at first.
Thanks for any information. We can't afford a mechanic right now.
Old Oct 12, 2010 | 09:56 AM
AbandonedBronco's Avatar
AbandonedBronco
Are you able to pull the distributor out? If it "just quit" it sounds like something on the electrical side broke.
Old Oct 12, 2010 | 10:21 AM
deadbishop12
I'm working on getting distributor out to check it first.
Old Oct 12, 2010 | 12:21 PM
deadbishop12
It is not distrubutor. Now going for timing gears.
Old Oct 12, 2010 | 01:54 PM
Wyowanderer's Avatar
Wyowanderer
Next step is to pull the timing cover. You'll want to pull the pan, as you'll want a new gasket when you pull the timing cover.
Jack up the engine
drain the radiator
Pull the pan
pull the harmonic balancer
pull the cam and valve covers
loosen the rocker arms and remove the push rods
remove the lifters-KEEP THEM IN ORDER!
pull the cam and change the gearset
DON'T BREAK THE CAM THRUST PLATE!
installation in reverse order
You might get away with leaving the pan in place. I've never tried.
Good luck-keep us posted.
Old Oct 12, 2010 | 04:53 PM
F-250 restorer's Avatar
F-250 restorer
Jack up the engine
drain the radiator
Pull the pan
I think you'll find gear teeth in the o.pan. With that many miles I'd replace the pump while there. Replace with all metal gears, Cloyes, from Summit Racing. Heck, if it were me, I'd think long and hard about lifters and cam too. 'Why is there never enough money to do it right, but always enough to do it over.'
Old Oct 12, 2010 | 06:11 PM
JimsRebel's Avatar
JimsRebel
here is a cheap cam, cant help with the rest.
New Competition Cam for Ford 240- 300 cu.
It has been listed for sale many times
Old Oct 12, 2010 | 08:13 PM
Wyowanderer
Yup. Might as well install a one piece pan gasket, too.
Old Oct 13, 2010 | 07:01 AM
deadbishop12
Got bolt out of harmonic balancer by wrapping old belt around outside and clamp it with 2 pairs vice grips. Haines book about useless. Bolts in gear puller from Auto Zone don't fit. Seem to be a size small or too big.. Thanks for input guys.
erik68
Feb 8, 2015 06:47 PM
restoringmy46
Mar 16, 2009 12:33 PM
ddafternoons
Feb 22, 2005 11:11 AM
Varnish
Jun 25, 2002 02:52 PM
FOMOCOMUY
Mar 17, 2002 03:32 PM
