What is the differance in intakes?
Old Oct 10, 2010 | 08:08 PM
mudder460's Avatar
mudder460
I am getting ready to depoy out for a while and I am getting my list of parts together to build my 300 when I get back. I am trying to figure out the differance between the Offy C, Offy DP or Clifford. I know with the Offy's you will need the heater spacer for the carb and the Clifford has it built in, other than that what is better and why?
Old Oct 10, 2010 | 09:55 PM
flipklos's Avatar
flipklos
The offy C is a single plane intake that is designed for a higher operating RPM.
The DP is a dual plane with small primary runners to boost intake velocity and thering efficency. It has larger secondary runners for greater airflow under hard throttle.
The clifford is a water heated single plane. I think the water heat would give one the best result especialy during the colder months. Other users will know more then I.
Old Oct 10, 2010 | 11:58 PM
F-250 restorer's Avatar
F-250 restorer
X2 what Flip said. The C manifolds supposedly more geared for racing. I have spoken with guys who could see performance drop and mph go up with the DP (dual port) Offies, after using a C.
Old Oct 11, 2010 | 11:17 AM
AbandonedBronco's Avatar
AbandonedBronco
I have an Offy C on one of my 300s and an Offy DP on the other.
I can definitely tell the difference between the two.
For starters, the 300 with the C has a 600 cfm carb, 3.55 rear, headers, no cats (yet), etc.
The 300 with the DP has a 390cfm carb, 3.00 rear, EFI exhaust, and a cat.
The DP version, even with higher gearing and a more restrictive exhaust, has a lot more snap in the throttle.
The C version doesn't have that low end torque feel, but has VERY smooth power all through the RPM band, and feels like it could rev forever.
I'm not sure which I like better yet, but there definitely is a performance difference between the two.
Old Oct 11, 2010 | 02:18 PM
1986F150six's Avatar
1986F150six
Nice comparison, AbandonedBronco.
Old Oct 11, 2010 | 05:57 PM
F-250 restorer
The DP version, even with lower gearing ...
"Uhhhh, 3.55 gears are lower than 3.00's.
Old Oct 11, 2010 | 05:59 PM
AbandonedBronco
I got that backwards. =P
Fixed...
Old Oct 11, 2010 | 10:03 PM
Harte3's Avatar
Harte3
Some have used a 4-holes pacer on the C to get a bit more columnar flow through the carb and raise the carb away from the cavernous opening in the manifold which can cause turbulence at the base of the carb and restore a bit of lower speed snap.
Old Oct 12, 2010 | 09:03 AM
mudder460's Avatar
mudder460
Ohhhh, such a choice. I am planning on using the truck for an off road play toy. I am thinking the dp would be the best then. I was just leaning towards the Clifford one since it had the water jacket built in...just to make it easier.
Old Oct 12, 2010 | 09:54 AM
AbandonedBronco
Come to think of it, it does have a 4 hole spacer underneath it.
Old Oct 12, 2010 | 08:21 PM
wasa 1500's Avatar
wasa 1500
I was leaning tward the dp, but summit was telling me no need for a heated spacer.
live in east tn. Thoughts???
Will be using efi exhaust, and a 4 barrel carb( not sure on brand yet ) on my 300 76 2wd
Old Oct 12, 2010 | 10:53 PM
Harte3's Avatar
Harte3
Even in TN you may experience soggy performance, stumble and hesitation without heat to the manifold. The heated spacer is more of a hedge against carb icing.
Triffecpa
Jan 29, 2015 04:49 PM
vntgtrk
Oct 7, 2012 12:42 PM
mattri
17
Feb 27, 2004 08:17 PM
aunchman
Apr 16, 2003 09:52 PM
len
Jul 16, 2001 07:53 PM
