Cliford/Offy/Hedman?
Old Feb 20, 2004 | 10:41 PM
mattri's Avatar
mattri
I know this has been discussed before and I've read all of the seperate posts I could find but I still have a few quesions. I'm building a 1980 Bronco. It originally had a 400, NP435 and the 9".
The 4spd and the 9 are staying, the 400 is already gone. I have an early 80s 300 (Duraspark) that's going to get rebuilt with a healthy cam (260ish) and a port/polish on the head. My question is about the induction and exhaust. This will be a daily driver with some offroading, nothing radical. I want to go with a 500 Edelbrock but am having a hard time deciding between the Clifford and the Offy intake. I like that the Offy is dualplane but with the cam and head work I'm doing I shouldn't lose low end with the Clifford. Also, which header? Is anyone running a Clifford intake and header? Or a Clifford with the Hedmans? Any info and/or ideas appreciated.
ps will be single 2.5 exhaust
Old Feb 21, 2004 | 09:57 AM
bremen242's Avatar
bremen242
I had a 500 edelbrock with Cliffy intake and headers, Had tons of low end.. it need a cam to put the power a little higher though.
I had cliffords single exhaust header, and it didn't fit worth a crap.
Old Feb 21, 2004 | 11:30 AM
mattri's Avatar
mattri
So I'm assuming you have the dual outlet now, what fitting problems did you have with the other?
Old Feb 21, 2004 | 12:00 PM
bremen242's Avatar
bremen242
Yes. The y-pipe wouldn't even mate up with the headers, and it hit the frame.
Old Feb 21, 2004 | 05:51 PM
mattri's Avatar
mattri
Sorry, maybe I'm reading this wrong but why would you have a y-pipe with a single outlet header?
Old Feb 21, 2004 | 06:06 PM
bremen242's Avatar
bremen242
Thats ok. The header comes in three pieces:
The front 3 cylinders come down to a collector (these are both relatively short)
the rear 3 cylinders come down to a collector
and a y pipe brings them down to the final collector.
Old Feb 22, 2004 | 12:59 AM
mattri's Avatar
mattri
Thanks for clearing that up. Did the upper collectors fit to the head well? If you bought just the upper collectors and not the y-pipe could you custom build one that would work better?
Old Feb 22, 2004 | 01:27 PM
bremen242's Avatar
bremen242
You could; it would be a bit of a pain, because the collectors come to close to the frame. I'll take a pic of the setup since I am going to my folk's house where the truck (well, actually the frame) is at, and you can get the idea.
Old Feb 22, 2004 | 07:58 PM
mattri's Avatar
mattri
That would be awesome, thank you. I'm trying to plan this build as completely as I can before I get started and the intake/header is really the only thing I haven't decided. I appreciate your input with this, I'll be looking foreward to those pics!
Old Feb 23, 2004 | 06:19 AM
bremen242's Avatar
bremen242
This are the pics; if you want, I can work you out a deal on the headers if you deside to go that way. I'd sell you the intake as well, but I discovered yesterday it has a crack going through the top side.. . thats what I get for leaving it outside for a year.
Old Feb 23, 2004 | 07:58 PM
mattri's Avatar
mattri
Thanks for the pics, that helps clear it up for me. What would you want for the headers? Which model (part# etc) are they. How long have you had them? Condition? And would they fit an 80 Bronco?
Old Feb 23, 2004 | 08:41 PM
bremen242's Avatar
bremen242
they are the ones above in the pics.. they are no longer in use.
they'll fit a bronco, and you'll have to fab a y-pipe. $40 plus the shipping, unless you can pick them up..
Old Feb 23, 2004 | 11:19 PM
mattri's Avatar
mattri
They look like they've been sitting a while, how bad is that rust?
Old Feb 24, 2004 | 06:34 AM
bremen242's Avatar
bremen242
it surface rust. I'd have to pull them to make sure, but clifford uses heavy tube and double welds them.. its up to you.. I can pull them and wire brush them up send pics if you want..
Old Feb 24, 2004 | 08:05 AM
mattri's Avatar
mattri
I'll take your word for it. 40 dollars sounds reasonable. I live in Denver so if you want to let me know how much it will be to ship, UPS or something like that would be fine, I'm in no hurry.
