Spruce Up Your Early Bronco with These Five Simple Upgrades
Ford Bronco will look even better inside, outside and when parked in storage with these awesome upgrade items.
If you have a Ford Bronco from the 1973 through 1979, the odds are good that probably gets around pretty well in the snow. However, with most regions with heavy snowfall using road salt to keep the roads from getting too slippery, many classic Bronco owners tuck them away for the winter. While tucked away, many owners like to add some upgrades as part of a winter project, so we found a handful of items from Bronco Graveyard that can spruce up any classic SUV from this era.
Popular Exterior Upgrades
First up, we have a couple upgrades that are ideal for anyone who likes to take their classic Ford Bronco off-roading.
The first is a pair of ActionTrax, which will help you get your Bronco out of loose footing. These handy items mount out back on the spare tire when not in use, but when you get stuck in sand or loose dirt, you can quickly remove them and stick them under the tires for a better grip. They are available in a variety of colors and they can be used with any vehicle, but they are a great addition in orange on the back of a classic Bronco.
Next, we have a RockSolid prerunner front bumper that creates an easy place to mount a winch on your Bronco. Shown here on a 1978 or 1979 model, you can see that this bumper includes a spot for a winch and some fog lights, while proving extra protection for the front end.
Heading Inside
If you use the cargo area in your classic Ford Bronco and the vehicle has been repainted inside, you will want to protect the metal floor. This 1966-1977 Ford Bronco rear rubber floor mat is a direct replacement for the OEM liner that went under the factory carpeting, so it will work under carpeting to reduce interior noise, but without carpeting, this mat will protect your fresh interior paint.
Wooden steering wheels are practically unheard of these days, but to properly recreate the classic look of the Bronco, one of these is a must-have. Bronco Graveyard offers this steering wheel with two different center caps, one with the Ford logo and one with the classic Bronco logo, and both will look great in the classic SUV. Also, you can get a chrome column adapted that matches the polished aluminum spokes, or you can get a black powder-coated adapter.
Safe Bronco Storage
Finally, if you don’t want to upgrade your classic Ford SUV at all this year, but you want to store it in style, you need this cool cover. This is a Ford licensed item, complete with the likeness of the classic grille and headlights up front with the model logos on the sides and rear. It is designed to perfectly hug the boxy lines of the classic SUV, which when coupled with the graphics leaves no question as to what is hiding under the cover.
Of course, if you need anything else for your classic Ford Bronco, the odds are good that Bronco Graveyard can help.
You must be logged in to post a comment.
