Getting Ready to do a Clean Wiring Install
Old 03-19-2017, 07:00 PM
oldracerjones's Avatar
oldracerjones
oldracerjones is offline
Getting ready to install a new harness on my frame off rebuild for a 1962 Flareside. Just about ready to put the cab back on and will start the rewire. I'm asking for any tips or tricks you might have when rewiring one of these. Any help is appreciated.
Engine installed after fabbing engine mounts for frame.
Old 03-19-2017, 10:18 PM
swoosh1958's Avatar
swoosh1958
swoosh1958 is offline
Are you doing a complete chassis wire loom? Which brand are you going to use? Following.
Old 03-22-2017, 08:05 AM
svolpone's Avatar
svolpone
svolpone is offline
i used an American Autowire harness. it was fairly easy. wires are well marked. if you have questions they are happy to help.
others have used other wiring harnesses. i'm sure they are all pretty similar.
Old 03-22-2017, 03:14 PM
swoosh1958's Avatar
swoosh1958
Does the wiring come with all the stock connectors? Does it come with the rectangular male and female connectors on the firewall?
Old 03-22-2017, 03:24 PM
TA455HO's Avatar
TA455HO
TA455HO is online now
Dennis, right?
For authentic style reproduction harnesses many people are going with this company. They apparently do a fairly exacting version with correct connectors. I can not say myself as I have not used them yet, but they have a good reputation.
Wiring Harnesses - Narragansett Reproductions - Wiring Harnesses and car restoration supplies
EDIT: Their Ford catalog is here. Scroll down to Commercial section for trucks, past all of the cars. About page 22....
http://www.narragansettreproductions...parts-ford.pdf
Chad
Old 03-22-2017, 03:42 PM
swoosh1958's Avatar
swoosh1958
So, if you use an American Auto wire harness. How do they make the connections? Do you have to have an original and cut the connectors off and splice them to the harness?
Old 03-22-2017, 03:43 PM
swoosh1958's Avatar
swoosh1958
DANG! Those are pricey Chad.
Old 03-22-2017, 04:12 PM
TA455HO's Avatar
TA455HO
I like Bill's saying. "You thought you bought a truck, but you really bought a hobby, and hobbies tend to be expensive."
I always nod when I hear that one.
It depends on what you want to do. These high-end reproduction harnesses might be better for a high-end restoration.
Many of the kits are at least somewhat universal and/or let you add extra circuits for electric seat warmers, backup cameras, etc. etc.. The idea is to remove all of the existing wiring, then use the connectors that come with the universal kit. Some of the fit and finish is left up to the installer in those cases.
One I have had experience with is M+H Fabricators. I and many others have used them for GM harnesses. They do nice work with original wire colors and connectors. But, they don't do Ford products.
Reproduction Wiring Harnesses for America's Muscle Cars
Old 03-22-2017, 04:29 PM
swoosh1958's Avatar
swoosh1958
DON'T DO FORD! What's wrong with those guys.
Old 03-22-2017, 04:46 PM
TA455HO's Avatar
TA455HO
I know it. At least they do GM. I've been working on getting my doors installed on my Trans Am. They're only like 5 feet long! Lol.
Chad
Old 03-23-2017, 08:22 PM
oldracerjones
Here is what I am using. Keep in mind I am not restoring the truck but making a more modern one in the areas of power and safety.
You are here: Shop Home >> Categories >> EZ Wiring Kits & Switches >> EZ Wiring Harness Kits
EZ Wiring 21 Standard Color Wiring Harness Kit
All EZ wiring kits use GXL 125 high temp cross linked polyethylene jacketed wire that is grease, oil, gas, and acid resistant. Each wire is labeled every 5” Its entire length so checking a circuit is EZ ! COLOR coded wire! EZ wiring is the EZ way ! Each circuit wire is labeled so you know exactly where it goes -- EZier to wire --
EZier to trouble shoot ! Our best kit -- the EZ-21 - contains 18 fuses and 21 circuits.
http://www.ezwiring.com/store/ccdata...geMain_0_4.jpg
+ EZ 21
+ 18 FUSES 21 CIRCUIT
+ Radio, Coil, Dome Light, Backup/Cruise, Horn, Cigarette Lighter, Fuel Pump, AC/Heat, Radio, Turn Signal, Horn, ACC, Wiper, Gauges, Hazard, Fan, Power Window, Power Door Locks, Brake, Headlights (Color & Black have same)
Your Price:
$185.00
Old 03-24-2017, 08:26 AM
svolpone's Avatar
svolpone
svolpone is offline
American auto wire has the connections to the truck parts, but they have their own connections for their harness connections. You'll need their crimping tool, and it cost a bit of money. i have it, and we can talk about you buying it from me for cheaper than they charge for it if you want, or there are a bunch of them on ebay.
hope this doesn't get me in trouble with the FTE powers that be. i'm NOT actively selling this tool, but it's just sitting in my toolbox and i'll never be used again, most likely.
Old 03-24-2017, 07:06 PM
swoosh1958's Avatar
swoosh1958
svolpone, pm'd you.
Old 03-24-2017, 08:32 PM
oldracerjones
The crimping tool is worth every penny.
anthony f47
10-04-2016 05:04 PM
Tilleyman
25
01-18-2014 08:40 AM
Poison Oil Racing
16
05-29-2013 03:14 AM
JKfordfan
09-10-2006 07:15 AM
showtime946
01-19-2004 11:18 AM
Quick Reply: Getting Ready to do a Clean Wiring Install
