Cracked fuel filter
Old 12-08-2016, 12:52 PM
chorepail's Avatar
chorepail
chorepail is offline
Cracked fuel filter
Just wondering if someone could help me out Within the last month ive had 2 cracked fuel filters the filter up by the engine
Old 12-08-2016, 12:58 PM
Just Strokin's Avatar
Just Strokin
Just Strokin is offline
Help you how? Be a tad more specific please.
Old 12-08-2016, 01:26 PM
chorepail's Avatar
chorepail
was wondering if anybody had any ideas why they keep cracking couple months ago the low fuel pressure came on and the fuel pump seems a little more noisey than I remember
Old 12-08-2016, 01:29 PM
djousma's Avatar
djousma
djousma is offline
What year truck is it? The 2011's and early 2012 had a nut to tighten the filter into the housing. newer than that, they just drop in, and twist.
Where is the cracking occurring? Do you have any aftermarket gear up there?
Old 12-08-2016, 01:30 PM
LaxPlaya21's Avatar
LaxPlaya21
LaxPlaya21 is offline
That filter is pretty solid piece of plastic, I am not sure how it is cracking. Are you cracking it while installing it? I have found that some filters fit tighter than others. I put a little bit of lubricant on the plastic and it slides in smoothly!
Old 12-08-2016, 01:47 PM
chorepail's Avatar
chorepail
its a 13 and no aftermarket stuff no its happening days after I install it first time it happened it cracked on top this time it cracked all the way up the side
Old 12-08-2016, 02:05 PM
djousma's Avatar
djousma
djousma is offline
Are you using Motorcraft replacements? Or some off-brand.
Old 12-08-2016, 02:07 PM
Dakster's Avatar
Dakster
Dakster is offline
I know some people will use a strap wrench and a socket to help with the removal. Greasing the threads helps too.
I try to be careful to make sure the entire socket end is completely in the formed nut at the end of the filter housing when I turn it. It's also possible that you are over tightening past the "stop" as well. There is a little piece of metal or plastic sticking out that tells you the filter is tightened down all the way, tighten it past it and it breaks the filter housing.
Old 12-08-2016, 02:09 PM
djousma's Avatar
djousma
djousma is offline
Dak, Unless I'm confused, he said its the engine mounted filter that is cracking.
Old 12-08-2016, 06:34 PM
chorepail's Avatar
chorepail
yes it is the engine mounted filter the first filter was motorcraft the second was from napa
Old 12-08-2016, 06:40 PM
djousma's Avatar
djousma
djousma is offline
Dont have an answer for you, but I would stay away from the napa filters and only go with OEM motorcraft filters. they can be had from various places for about $50 a set.
Old 12-08-2016, 08:13 PM
Dakster's Avatar
Dakster
Dakster is offline
I got confused... probably because I have not heard of those cracking.
Old 12-10-2016, 08:34 AM
69cj's Avatar
69cj
69cj is offline
I just changed my fuel filters yesterday and the new, Motorcraft, filter was very tight going in. I should have lubed it but got so far and it didn't want to come back out. I'll deal with that the next time the filter is due.
menze46
10-19-2019 10:33 AM
Byram
6.2L V8
02-24-2012 06:27 PM
61 uni
11-22-2008 08:20 AM
dyoungen
10-04-2006 11:59 PM
Finally
02-01-2006 11:01 AM
Quick Reply: Cracked fuel filter
