Parking Brake
This may be of help to you. I have not had a chance to do it to my EB or either of my 79's but intend to.
Brake Warning light / emergency brake warning light - ClassicBroncos.com Forums
X2 on NO 73-79 trucks did not come with a indicator light when the park brake is on. That is a new vehicle ism...I would try the link/product that redmt79 sent you. FYI it is for 66-77 smaller Bronco's though, not full size 78/79 Bronco's.
And do NOT mess with that red "Brake" warning light set up on your dash. That light is wired to your brake proportional valve and is suppose to light up when you 1st start the truck to do a circuit test, and then go out.
If should only come any other time if you have a major failure of you brake system. Like a blown line/lean in the sealed system and the floating piston inside moves to trip the light.
A actual brake pedal switch modded to work on the park brake would be a route to try, just wire it to a separate added on light.
silar
09-22-2014 09:59 PM
LFDavidson
01-28-2014 05:54 PM
Al Barrs
10-12-2004 12:43 PM
