Door striker ?
Old 10-01-2012, 06:30 PM
V10man's Avatar
V10man
V10man is offline
Door striker ?
I did my anti rattle kit and door weather strip this weekend. The drivers door closes ok but firm. The passenger door is a whole nother animal. It doesn't want to close unless I give it a good slam. I tried adjusting the striker but it still hangs on the striker. Then I noticed something. The drivers side striker bolt is thicker and has a "rolling" thingy on it. The passenger side is thinner and doesn't have this thing. Am I correct in thinking the passenger side "roller" thingy is gone and I need a new striker bolt?
Old 10-01-2012, 08:23 PM
VocaTexas's Avatar
VocaTexas
VocaTexas is offline
There should be a plastic sleeve on the striker bolt. If it's gone, then that's your problem. I've seen heater hose used on them in a pinch, but a new striker is a much better option.
Old 10-01-2012, 08:26 PM
hermancm's Avatar
hermancm
hermancm is offline
Napa has a good deal on them, I think I paid $7 ea. a few months ago.
Old 10-01-2012, 08:55 PM
Stinky7-11's Avatar
Stinky7-11
Stinky7-11 is offline
After you replace the striker adjust the door so the lines are right even if it is hard to close then leave it for a few days, I think you will find that time is your friend. If you can park it in the sun and warm it up even better. good luck.
Old 10-01-2012, 09:16 PM
74 F350 SCS's Avatar
74 F350 SCS
74 F350 SCS is offline
I too replaced my weatherstripping this spring and the doors didnt want to close easily or tightly without slamming it. I adjusted the striker pin about 100 times but finally got it close. I have found that after a month or so, they gradually soften up and then you need to readjust the pin. Keep readjusting every month or so until eventually they close properly. In my last pickup, this took about 6 months of adjusting.
Old 10-01-2012, 11:58 PM
V10man's Avatar
V10man
V10man is offline
I'll pick one up. I think there may be alignment issues with the door as well. I'll try and get a pic of the door. I really dont want to mess with the hinges. Can that even be done with the front fender on?? lol
Old 10-02-2012, 06:20 AM
77F150Jason's Avatar
77F150Jason
77F150Jason is offline
Maybe the hinge pin is so worn the door is sagging creating enough of a misalignment. I don't know. I agree that it will soften up with time though.
Old 10-02-2012, 07:05 AM
bamaf150's Avatar
bamaf150
bamaf150 is offline
I replaced my strikers out of the help section at the local auto parts. Dont bother just buying the plastic sleeve (they have those too)as I see no good way of replacing them, New strikers are cheap enough. Dont spray them with silicone lube either, dont ask how I know that white lithium is whats called for in the manual. You may possibly need these hinge pins though:
1973-79 Full Size Truck/bronco - Door Parts - Door Hinges
Old 10-02-2012, 05:33 PM
V10man's Avatar
V10man
V10man is offline
Got a new striker and it does latch much better. Door is still off tho. I did move the striker up so the door is even all around. It is very difficult to open/close with the striker in this spot. moved it down a little and it opperates much better. Here is a pic. You can see how it gets narrower towards the top. The windshield side is wider.
On another note, took her to get a bath today and with the high pressure wash she leaked at the top of the doors both sides and thru the wing windows. (haven't changed those seals yet)
Caleb H
17
02-09-2011 08:50 PM
93MARKIII
10-26-2010 03:14 AM
mantta
03-22-2007 10:14 PM
LesPaul
08-05-2003 08:09 AM
Pastmaster
09-18-1999 07:30 AM
Quick Reply: Door striker ?
