OD light blinking!!!! 02 F250 7.3 Auto Tranz.
I wanted to post this info to help anyone who has had a problem with their OD light blinking and shift problems. This past week my od light started blinking and when I shifted into drive, it was stuck in overdrive. When I shift into 1st it would go to 2nd and stay there. So basically I had 2nd and overdrive. I started replacing sensors like the VSS, and checking the wiring warness. Took it to a transmission garage and they told me it was toast. Then I decided to bite the bullet and buy a new tranny. After replacing the tranny it did the same thing with the same codes showing. Then I got smart and checked the fuses. Of course it was as simple as a blown fuse causing all the trouble. In my truck it was fuse 23 under the dash. A 20 amp fuse that was listed as engine control. Im not saying that in every case if the OD light starts blinking it's as simple as a fuse but in my case it was, so lesson learned. Always check the fuses first. I hope this may help someone else in the future.
I was pretty ticked off at the Transmission Shop but I put the tranny myself so there wasn't much I could say but I defintely let them know that they were wrong and I would'nt be back. I think some of the codes were like Torque Converter coast clutch electrical circuit, Solenoid A Circuit, Solenoid B Circuit. I can't remember the actual numbers but if I can find the paper I had them wrote on I'll post them later. I hope this post helps someone else before they take some bad advice and make the same mistake I did.
OUCH!
That's another reason forums like these are so valuable.
I had the same problem about 3 or 4 months ago. I fixed it with just the fuse (no other cost). I try to open every "OD light blinking" thread I see now in hopes of saving someone some money or at least giving them something to look for.
Did you check them visually or with a multimeter? Mine checked out fine visually, but when checked with a multimeter it was obvious that the fuse was loose in the socket. The connection was intermittent. Might be work another look.
Sounds like the same thing that happened here.
https://www.ford-trucks.com/forums/9...ml#post9225163
96 flashing OD light
I have a 96 f250 7.3 liter. So a few months ago my OD light started flashing. I found out it was the #13 fuse in the fuse box. Last night by OD light started flashing again. This time the #13 fuse was good. I rasked my brain for hours trying to figure out why. After diving into the owners manual, I found out there is a power distribution bow. Look in the owners manual to see the diagram. There is a 50A fuse in the power distribution box that controls fuse 13 and some others. I found out while my #13, 15A fuse was good. The 50a fuse that controls it was not good. This is the 50A fuse that is closest to the driver side of the truck. So I looked at the fuse and the fuse was actually good but the connections were dirty and it was causing problems. If you have problems check these fuses and make sure they are connecting correctly.
drembedded
22
08-17-2011 09:43 AM
grizzly11
16
07-24-2010 02:54 PM
gametime2387
1999 to 2016 Super Duty
02-04-2010 10:17 AM
