New to forums but need help - 94.5 f250 7.3turbo idi has new remanufactured e40d tranny/new torque converter has shifting problem again new tranny has all upgrades was fine after install for 2 months. 1st the overdrive light started flashing and shifting in and out of overdrive shifting hard -checked all fuses and wiring found nothing but after was shifting fine and no flashing od light -2nd it started acting up same way a couple weeks later I replaced speed sensor in rear end and no probems shifting runs great and after a week or two speedometer stops/starts working tranny drops out of od and downshifts-no flashing od light/no hard shift-starts working shifts normal couple days later same thing. Bad wire somewhere? Thx for any ideas
Its mechanical and it goes to 0 then all the way to 120 then starts working again and repeats' and the tranny goes in and out of od. I stop, turn it off and its fine again
A '94.5 truck should have a speedometer that goes to 85 MPH and a digital odometer, both electronically driven by the VSS. If you have something different, can you post a pic?
Well, you're posting in the wrong section, and the transmission control is quite different with the IDIs. But this may be a speedometer/PSOM/VSS problem, not a transmission control problem. Anyway, your pic does not show a mechanical odometer, nor does it show a 120-MPH speedometer, as you stated in post #3. So once again, when the speedometer malfunctions, does the odometer continue to display a number, or does it go blank?
Sorry again- just realized I was posting in wrong section-I say mech. as in not digital so where would a number be showing? I replaced the vss in diff. the psom seems to jump around when I turn it off is the only other thing I've noticed
well having issues now with abs light coming on and speedometer quits working ,tranny downshifts. Had instrument cluster rebuilt and all gauges work now-rebuilder said he wasn't sure if speedometer was prob. but had issues so new board. bad wire somewhere? any ideas where to look? what to do nxt?
Thx for reply - id like to hit it with a sledge - Ill start tracing it again and looking closer at that area - would that be the reason the ABS lights when no signal from VSS?
It very well could be. The 96 C&C had the ABS light on, and no/bouncing speedo when the wire needed repaired.
