frame cracked at steering box 77 f150
Old 09-05-2010, 09:42 AM
kelly77's Avatar
kelly77
kelly77 is offline
would like some info on repair kits available for cracked frames at front bolt on steering box
Old 09-05-2010, 12:38 PM
southernboy0122's Avatar
southernboy0122
southernboy0122 is offline
Mine is like that too. Im going to be stop drilling it to prevent it from cracking more. And far as repair kits, welding and prolly welding a thicker plate on top of it. I wonder if this is a common thing on these trucks?
Old 09-05-2010, 02:23 PM
c.l.nye's Avatar
c.l.nye
c.l.nye is offline
it is fairly common with big tires and abuse. What I did was use a second piece of frame from a donor truck and cut out a "patch" piece to go over the origional frame. I stop drilledthe cracks,"V"ed them and welded them up then ground downthe welds and fully welded the patch panel over it all. It worked for about 10 years before I changed frames because of rust.
Old 09-05-2010, 07:00 PM
78ford351m's Avatar
78ford351m
78ford351m is offline
Change frames? I bet that was fun.
Old 09-05-2010, 08:39 PM
c.l.nye's Avatar
c.l.nye
c.l.nye is offline
It was not all that bad. just labor intensive.
Old 09-05-2010, 10:46 PM
patsfan1's Avatar
patsfan1
patsfan1 is offline
i have a good long bed frame for sale a 100 bucks
Old 09-06-2010, 08:05 AM
78ford351m's Avatar
78ford351m
Patsfan1, I Pmed you and your pms are off. Where are you located? Pics?
Old 09-06-2010, 09:50 PM
patsfan1's Avatar
patsfan1
patsfan1 is offline
the frame i have is long bed its been painted with rustolem i am in lexington.
Old 09-06-2010, 10:01 PM
XzXPatrickXzX's Avatar
XzXPatrickXzX
XzXPatrickXzX is offline
Is it a 4x4 frame?
If 78FORD351M Isn't interested and its a 4x4 frame I am. I Live in southern Kentucky and would be willing to pick it up.
Old 09-06-2010, 10:06 PM
78ford351m's Avatar
78ford351m
Lexington ohio? I am in ohio.
Old 09-06-2010, 10:17 PM
gus11208's Avatar
gus11208
gus11208 is offline
If its a 4X4 frame the easiest fix is to weld a 1/4" plate onto the frame behind the stearing box. This is a common problem and if you replace the frame with another you might be haveing this problem again anyways. Just make a cardboard template to mark the shape and size of the plate and where the bolt holes for the power stearing box need to go. I just did mine last year. I had about $30 into it.
Justin73supercamper
11-30-2016 08:16 PM
gman97005
06-05-2016 06:04 AM
RDunlop
02-25-2011 02:38 PM
89f150mike
07-11-2006 09:01 PM
cookster
01-30-2002 02:20 PM
Quick Reply: frame cracked at steering box 77 f150
