Needing to talk to 77 f-250 4x4 owner????
Does anyone have a 77 F-250 4x4?? Can you tell me how you steering box is mounted to your fame??? On the inside or the outside ?? Mine is mounted on the inside of frame with a spacer mounted between the box and the frame. Why I don't know. Previous owner did some modifiing and some prefabing.
I have a 1977 Ford F-250, and my steering box is on the outside of my frame. Has been ever since my dad bought off of the dealers lot in '77. Because I didn't know if it would be in my way, when I was ready to put my lift on it. It hasn't been a problem, but yeah, my is mounted on the outside of my frame.
Hope this helps you.
Jeremy J. Gross
Jeremy J. Gross
My truck has the divorced tranny case, 3 drive shafts, 351 400m.
The previous owners put a spacer block between the frame and steering box which is mounted on the inside of frame. The truck once had cross over steering and now I'm in the process of putting 78-79 f-150 4x4 steering linkage on the truck. Tierod from knuckle to knuckle with an adjustable draglink that connects to the tierod and then goes to the pitman arm. It turns pretty tight to the right but to the left the turning radius stinks. Any suggestions would be appreciated. Thanks David
Earnie Rosenow
11-10-2016 11:40 AM
Amphihauler
09-26-2016 09:17 AM
dannyboy_86
05-09-2016 02:33 PM
v8only
06-23-2011 08:58 PM
kelly77
09-06-2010 10:17 PM
