Steering Box Started Creaking
Old Feb 2, 2011 | 07:07 PM
RDunlop's Avatar
RDunlop
1997 F250 7.3PS 4x4
With the engine off - when I turn the steering left or right a loud creaking sound comes from what seems to be within the steering box.
I can't see any movement or cracks in the frame. Could the noise actually be coming from within the steering box itself?
...rd
Old Feb 3, 2011 | 11:42 AM
tbone heller's Avatar
tbone heller
Check your ball joints & tie rods. Grease them up.
Old Feb 3, 2011 | 11:51 AM
RDunlop's Avatar
RDunlop
Will do - I'll let you know if this does the trick.
Thanks...rd
Old Feb 25, 2011 | 11:29 AM
RDunlop's Avatar
RDunlop
Lower Ball Joints Maybe?
Thanks...rd
Feb/25/2011: I greased the tie-rod ends and upper ball joints but noticed that the lower ball joints are still original - no grease nipple...
Could the lower ball joints be rusty and/or seizing up inside? I noticed that the steering is becoming tight and it doesn't track back to center well, after turning a corner.
Any other Ideas?
If I remember right, the lower ball joints are pressed in. I assume need heat and a pickle fork to get them out and a press to get them back in...?
Thanks guys!
Old Feb 25, 2011 | 11:33 AM
427 fordman's Avatar
427 fordman
support the front end on jack stands and put a big pry bar under the tire and pry up and see if there is any movement on the ball joints.
Old Feb 25, 2011 | 11:55 AM
RDunlop's Avatar
RDunlop
Thanks I'll check this...rd
Old Feb 25, 2011 | 02:11 PM
RRranch's Avatar
RRranch
retorque the three bolts holding the steering gear on too. They come loose with time.
Old Feb 25, 2011 | 02:38 PM
stubborn66's Avatar
stubborn66
You can aslo try taking off the tie rod end on each side with the wheel raised and see if it will turn smoothly by hand, if you have a frozen joint I think you will feel it.
MDSuperDuty
Jul 23, 2016 09:19 AM
TX Grit
Jun 3, 2016 08:51 PM
4WheelDriveVan
Jan 8, 2011 03:35 PM
rustyolred27
Mar 25, 2007 12:02 PM
oxbow
Apr 8, 2001 07:45 AM
