Error code 0603 pcm
Error code 0603 pcm
Ok so i have a late 99 PSD and i just recently replaced the IDM and the truck finally started. checked the codes now it is throwing this code. I do have a edge progammer on it. recently the truck has had a starting problem and the wait to start light would not come on (only once in a while it would come on after turning the key on and off a few times) and the truck would start finally. I did have a code that read 1470? i think, that the IDm signal not detected or failure, thats why i replaced the IDM.
What does this code mean? (P0603)
Does this have anything to do with the IDM? Or chip?
Think i could have a short somewhere in a wire?
Bigdaddy
Bigdaddy
This shouldn't be an issue for what you are experiencing. The P0603 Internal Control Module Keep Alive memory (KAM) Error is fairly normal when using a programmer.
To see if you have a bad PCM power relay swap it out with the blower motor relay to see if you get the WTS light every time you turn key to on.
So i replaced the pcm power relay and still nothing... so my next question is anyway i can check the ignition switch to see if it's bad? I've been checking all wires and nothing looks bad or any indication they are bad.
I did disconnect the batteries after reinstalling the pcm. so i think im good there now....
other thing when i plug my programmer in to get codes it wont connect unless that WTS light is on... Any ideas???
Thanks yall
Bigdaddy
Thanks yall
Bigdaddy
Ted50426
03-03-2014 12:13 PM
