Error code 0603 pcm
Old Aug 12, 2010 | 12:01 AM
bigdaddys99's Avatar
bigdaddys99
Error code 0603 pcm
Ok so i have a late 99 PSD and i just recently replaced the IDM and the truck finally started. checked the codes now it is throwing this code. I do have a edge progammer on it. recently the truck has had a starting problem and the wait to start light would not come on (only once in a while it would come on after turning the key on and off a few times) and the truck would start finally. I did have a code that read 1470? i think, that the IDm signal not detected or failure, thats why i replaced the IDM.
What does this code mean? (P0603)
Does this have anything to do with the IDM? Or chip?
Think i could have a short somewhere in a wire?
Bigdaddy
Old Aug 12, 2010 | 12:05 AM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
This shouldn't be an issue for what you are experiencing. The P0603 Internal Control Module Keep Alive memory (KAM) Error is fairly normal when using a programmer.
Old Aug 12, 2010 | 06:46 AM
Franko72's Avatar
Franko72
Molon Labe
^^^^What Clay said, I get the 603 code every time I pull the chip or unplug my PCM, its not a big deal.
Old Aug 12, 2010 | 01:39 PM
bigdaddys99
alright thanks guys
Old Aug 12, 2010 | 09:31 PM
PaysonPSD's Avatar
PaysonPSD
As far as having to turn the key on and off a couple of times before it will start it may be a bad contact in the PCM power relay, or the relay in general is bad. Could also be a faulty ignition switch.
Old Aug 15, 2010 | 02:41 PM
bigdaddys99
Yeah my Wts light isn't working again it only works when it wants to. Im going to check and probably get a new one a see if that works.
Old Aug 15, 2010 | 02:58 PM
PaysonPSD's Avatar
PaysonPSD
To see if you have a bad PCM power relay swap it out with the blower motor relay to see if you get the WTS light every time you turn key to on.
Old Aug 16, 2010 | 07:03 AM
wolfrace's Avatar
wolfrace
You like apples?
I have gotten this code when my battery has been discontected, have you discontected yours since the last time you cleared the codes?
Old Aug 17, 2010 | 10:47 PM
bigdaddys99
So i replaced the pcm power relay and still nothing... so my next question is anyway i can check the ignition switch to see if it's bad? I've been checking all wires and nothing looks bad or any indication they are bad.
I did disconnect the batteries after reinstalling the pcm. so i think im good there now....
other thing when i plug my programmer in to get codes it wont connect unless that WTS light is on... Any ideas???
Thanks yall
Bigdaddy
Ted50426
Mar 3, 2014 12:13 PM
kmooservice
Oct 2, 2013 02:52 PM
snakedoc
16
Oct 1, 2011 12:19 PM
Tone Tone
25
Jul 2, 2008 01:07 PM
kyoung
Sep 11, 2006 06:27 PM
