Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1970? F600 VIN Decode
Old 06-16-2010, 10:41 AM
awhtx's Avatar
awhtx
awhtx is offline
I have located what I think is a 1970 F600 Cab/Chassis. It has an FE series engine in it with a 4 speed transmission and 2 speed rear axle. Can someone decode these numbers?
VIN: F61CKH52419
Model: F61
Body: 4C8
Trans: A
Axle: F3D
164 HP @ 3800 RPM
The following users liked this post:
Old 06-24-2010, 03:59 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
VIN: F61CKH52419
Model: F61 The MODEL code is composed of 4 digits, the 4th is missing.
Body: 4C8
Trans: A
Axle: F3D
164 HP @ 3800 RPM
F61 = F600 2WD (gas).
C = 330 2V Meduim Duty FT engine.
K = Kansas City Assembly Plant.
H52419 = 1970.
F61? = F600. I cannot post what the GVWR is without the 4th digit.
4C8: 4C = Black Heavy Duty all Vinyl / 8 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission.
F3D: F3 = Eaton Model 15201 2 Speed Rear Axle / 6.33/8.81-1 / 15,000 lb. Rear Axle Capacity // D = Ford Rockwell Timken-Front Axle / 7,000 lb. Front Axle Capacity.
164 net HP @ 3,800 RPM.
The 1968/72 330 2V Medium Duty FT engine shares a few parts with the 360 2V FE engine, the crankshaft is the same.
FE engines were not installed in anything larger than an F350.
Old 06-24-2010, 11:23 AM
awhtx's Avatar
awhtx
awhtx is offline
Bill,
Thanks for that information.
I assume that the FE/FT engines are interchangeable so is there any way to tell externally which engine it is? Or do the 330/360/390 all look the same?
Alan
Old 06-24-2010, 12:02 PM
NumberDummy
Alan
The engines are not interchangeable. People do swap them around, but it's not a simple bolt in installation.
The 330 2V Medium Duty FT engine shares some parts with FE engines.
The FT 330 2V HEAVY Duty, 361 2V & 391 4V share only a few parts with FE engines.
FE/FT engines look basically the same. The exhaust manifolds are different, as are the carbs, some of which are Holley's with governors mounted on them.
The front/rear engine mounts are different. FT's have one front mount in the center, two mounts at the rear connected to ears on the bellhousing-then to the crossmember.
The only FE engines that mount like this are 1965 F100/250 4WD 352 / 1966 F250 4WD 352 / 1965/67 F350 352. All other FE's have two front mounts, one rear.
Strip all the accessories off, and without a bellhousing, your guess is as good as mine whether the engine is an FE or FT!
Old 01-27-2011, 09:21 PM
mangustrucking's Avatar
mangustrucking
mangustrucking is offline
I just bought a 1970 ford f600 dump truck and was just wondering what all the vin meant F61DKG78308 model F610
Old 04-14-2017, 03:32 PM
pjbible's Avatar
pjbible
pjbible is offline
Unhappy Need vin decode help
vin C70NU381608
I do not have a title and am trying to figure out what this vehicle is?
I do not know the year for sure, I am guessing 1970.
It is a tilt cab truck.
I think the C70 is for C700 series.
I do not know what the N is for.
I think the U is for made in Louiville.
Can anyone tell me for sure?
Old 04-14-2017, 04:38 PM
NumberDummy
F61 = F600.
D = 330 2V H/D FT engine.
K = Kansas City MO Assembly Plant.
G78308 = 1970.
F610 = F600 .. 21,000 lbs. Gross Vehicle Weight Rating.
Old 04-14-2017, 04:42 PM
NumberDummy
Originally Posted by pjbible
VIN: C70NU381608
C70 = C700 Tilt Cab.
N = 302 4V (Lincoln derived Y block).
U = Louisville KY Assembly Plant.
381608 = 1963, assembled February 1963.
Old 04-14-2017, 06:21 PM
pjbible's Avatar
pjbible
pjbible is offline
Smile vin info
Thanks for the info.
I am glad to know the engine size.
In case you were wondering, this is a cement truck with a sleeper cab.
canyoncat
Large Truck
44
01-21-2022 06:56 AM
EMH_metals
Large Truck
10-06-2020 03:35 PM
Signgonzo
Large Truck
04-13-2018 01:00 PM
Sam Hamilton
Large Truck
04-05-2018 07:21 AM
Damen69
11-19-2016 10:28 AM
Quick Reply: 1970? F600 VIN Decode
