Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
1977 F600 Decoder
Old Apr 27, 2017 | 05:18 PM
Signgonzo's Avatar
Signgonzo
1977 F600 Decoder
I was hoping I wouldn't have to bother any FTE folks but I can't for the life of me find a VIN decoder for my 1977 F600. Having a heck of a time finding brake parts for the old girl. I would appreciate any assistance. Thanks!
VIN# F61EVY40180
WB 212
Type GVW F611
Axle E3M
GVWR 20200
DSO 74
Old Apr 28, 2017 | 09:34 AM
CelticOne's Avatar
CelticOne
Regular User
Here is what this site says VINwiz Decoder
VIN Format: 1961-1980 Ford truck
Decoding: F61EVY40180
Digit Usage VIN Decoded
1-3 Series F61 F600
4 Engine E Unknown!
5 Plant V Kentucky Truck
6-8 Mod Yr/Mfg Date Y40 1977 (Mfg 1976 or 1977)
6-11 Sequential Serial # Y40180 Y40180
Serial numbers are sequential per plant
Bill (AKA NumberDummy) will chime in with corrections, particularly the engine code.
Old Apr 28, 2017 | 09:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What parts do you need?
VIN: F61EVY40180 / WB: 212 / COLOR: Omitted / TYPE/GVW: F611 / BODY: Omitted / TRANS: Omitted / AXLE: E3M / MAX GVW LBS: 20200 / DSO: 74
F61 = F600 2WD (gas).
E = 361 2V or 4V FT engine.
V = Kentucky Truck Assembly Plant.
Y40180 = 1977.
212" Wheelbase.
F611 = F600 2WD (gas), 20,200 lbs. GVWR
E3M:
E3 = Eaton model 16244 Two Speed Rear Axle / 6.50/9.04 / 17,500 lbs. Rear Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with P/S
20,200 lbs. Gross Vehicle Weight Rating.
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
Brake info depends on the size of the brake shoes (4 possible front/rear sizes of shoes) and the weight capacity of the front and rear axles.
Old Apr 28, 2017 | 11:37 AM
Signgonzo's Avatar
Signgonzo
Thanks Gents! And thanks for the speedy response as well. This should help me a bunch in my quest. I tried VINWIZ, couldn't get it to work.
Thanks again.
Old Apr 12, 2018 | 09:14 PM
Oldtruckyoungman's Avatar
Oldtruckyoungman
Banned
1977 F600
Hey I have a f600 that I was hoping to get the most information about it in regards to the engine/transmission.
The vin is F61EVY22055
Under the vin the is
W.B. 158, I'm not to sure about this
Color H, (do not really need this but maybe fun info)
Type/G.V.W F614, not sure what the 4 means
Body EB8, I do not understand this.
Transmission Manual, I understand this.
Max GVWB LBS. 22000, I understand this.
DSO 738061 I'm not to sure about this.
I appreciate any help you can provide and thank you in advance for your time
Old Apr 13, 2018 | 12:06 AM
NumberDummy
Y22055 = 1977.
158" Wheelbase.
H = Wimbledon White.
F614 = F600 2WD (gas), 22,000 lbs. GVWR
EB8: EB = Blue Vinyl / 8 = 81B Custom Cab.
M = Clark model 285V 5 Speed Direct.
F3M:
F3 = Eaton model 15201 Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Axle Capacity.
M = Ford 7,000 lbs. Capacity Front Axle with Power Steering.
22,000 lbs. Gross Vehicle Weight Rating.
738061:
73 = Salt Lake City UT Ford District Sales Office, where the original selling dealer ordered the truck from.
8061 = Domestic Special Order number, truck ordered special by the original purchaser, not "bought off the lot."
Please type further questions in the LARGE TRUCK forum, most members of this forum have pickups.
Old Apr 13, 2018 | 12:39 AM
mikeo0o0o0's Avatar
mikeo0o0o0
F61EVY22055
F61=F600 gas conventional cab
E=361 XD 4bbl V8
V=Kentucky Truck Assy.Plant
Y2205= Built March 1977
WB 158=158" Wheel base
Color H=White
Type/GVW F614= F600 22000 GVW , 7000 GAWR Frt, 15000 GAWR rear
Body EB8= (E) Knit/vinyl custom cab (B) Blue (8) Regular steel chassis cab
Trans M= Clark 285 V direct 5 speed
Axle F3M= (F3) Eaton 15201 15000 lb capacity 2 speed 6.33/8.81 ratio (M) 7000 lb front axle
Max GVW 22000 = 22000 lbs max gross vehicle weight
DSO 738061= This truck was a special order through the Salt Lake City (73) district sales office
Old Apr 13, 2018 | 12:41 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Looks like we're both up tonight Bill
Old Apr 13, 2018 | 01:28 AM
NumberDummy
I was just gonna ask, what the hell are you doing up this late?
It's 11:28 PM in LA LA Land, 2:28 AM in Orangejuiceville.
I beat you to the decode by 33 minutes, must be slowin' down in your old age...
Old Apr 13, 2018 | 12:54 PM
Oldtruckyoungman
Banned
What does f3k mean?
Old Apr 13, 2018 | 01:00 PM
NumberDummy
What does f3k mean?
F3K: F3 = Eaton Two Speed Rear Axle / 6.33/8.81 / 15,000 lbs. Axle Capacity // K = Ford 5,500 lbs. Capacity Front Axle with Power Steering.
chrissmallwood
17
Jan 20, 2018 11:47 AM
TaylorDiabetoSwifty
Large Truck
Mar 20, 2017 12:51 PM
mpokoney
Large Truck
Aug 3, 2015 12:08 PM
phillip low
Large Truck
Jan 30, 2013 03:18 PM
Lad4811
Large Truck
Aug 4, 2012 06:13 PM
