swapping a 302 with a 300
on
This swap is a lot more complicated that it may appear. Both motors share transmissions but just about everything else is different, and since it is likely that the '95 is mass air and the '93 isn't and the fact they're for different engine types the wiring harnesses are not at all similar or interchangable, so you will be doing a bunch of wiring modifications. It would be far easier to simply put another 5.0 or even a 5.8 into the '95.
If you have both trucks, swap over the wire harness thats under the hood with the 300. The bulkhead(firewall) connector I think will hook up but with a few wires needing changed around depending on years. A GOOD wiring diagram for both trucks will help on that.
Also the engine mounts to the frame will have to be changed as they are for V8 or I6 only.
I will have to consult ford fuel injection and see what comes about with the wiring, and switches, I am wondering and almost certain I will have to do a cluster change as I THINK, they are different with the model years, maybe somebody can classify.
The reason I am importing the 300 is the fact it has under 40,000 and the drive train is good, the frame is gone I will be back and forth here I am sure.
300 I6 no good for me
I have two f150's one is a 1991 and the other is a 1992 both have the 300 fi with e4od i baught these trucks thinking they will get good mpg and still pull good boy was i wrong neither one gets over 13 mpg and they will kick out od on the list little hill iam not saying that the 302 is better because it is not i have had one of these as well the only real good engine to have in half ton would be the 5.8 or 351 it pulls a lot stronger and still gets about 12 to 13 mpg besides that installing a 300 i6 in one of these trucks really stinks i believe installing a 460 would be easyer there is a reason that ford only put one engine instal hanger on the 300 and that is on the front because the engine just about has to go in the engine compartment vertically unless you remove the front clip. i have done extencive research and develoment on the fuel system and timeing on 300 and even changing the injectors and regualtor you still will ony get around 14 t0 15 mpg good luck with this but if i had it to do over i would go with the 5.8 instead
the '95 would be a mass air OBD2 truck correct???? if so i'm pretty sure your going to be changing the harness in the cab as well. new engine towers and motor mounts are needed. either air hammer or use a cutting torch to get the rivets off the old engine towers to get them off. i torched mine out w/ out hurting the frame at all or the towers. i just threw out those I6 engine towers too.... i think they are down in the pasture.
Ok, so your looking at interior wiring harness, under hood wiring harness, A/C lines, power steering lines, etc, etc..... lots of little things that have to be changed.. i'm going from 300 to 302.. let me know if you need anything
Waterace42, ur new here.. welcome. I don't really know what you mean about the 302 not getting good mileage.. the truck that my 302 came out of was my grandfather's old truck and he got 20-21 mpg with it everyday of the truck's life. we will see how it does in my truck once we get it running with 4.10's and 4x4, but i still can't see what your talking about... heck the 300 i took out of this truck got 16mpg w/ 4.10's and 4x4..
i guess our fuel is weaker here in oklahoma i never seen or herd of any body getting over 16 mpg with any 302 powered ford truck iave had 3 of them my self 86 witch was the first year of fi on the 302 1988 and also a 1992 hell my father in law owns a local mashine shop and parts store and he uses a 1989 f150 with the e4od and 302 and his only get 13 around town and it does not have enough power to get out of its own way
I have an 89 f 150 super cab. 4x4 5 sp. with the i6, its my first ford I like it, I use it for daily driving and mudding, It loves those hill climbs. (its lifted and sitting on 33's. I plan on putting some 3.55 gears in it if I get find em cheap, I only have the 3.08 in it now. Good luck youll love the motor
BuiltFordTough302
WTB - Ford Trucks & other vehicles
08-28-2014 03:53 PM
Ranger80
10-22-2013 09:23 PM
ericsbadf150
01-22-2001 06:40 PM
