Hi Performance 460ci Main bolts or Studs ???
Hello, its a high performance 557ci build with around 600 horsepower & Torque so i guess i will order the Arp main Studs, as i did read before in a forum the factory main bolts were pretty strong, i did buy head studs for the Edelbrock 61649 C/J alloy heads so it wont hurt to spend a little money & go with studs for the main caps, thanks 4 the info.
With Bottom Tap Im guessing you mean make sure the studs are in all the way ??? Yes will use loc-tite on main studs, with head studs use loc-tite ??? Or silastic gasket incase a stud passes thru a water passage, Thanks again.
No Jamie, they make what is called a bottoming tap for cleaning up and cutting threads in blind holes like the main bolt holes on your block. That gives you nice lean smooth threads all the way down and makes the studs get a better hold.
Also there is still some debate on studs vs bolts on these engines. I was running bolts but also had a main girdle at over 900hp with no cap walk. I think honestly that bolts may have a slight advantage on the mains but they are big enough that any aftermarket fastener is going to give you plenty of strength IMHO.
Thanks Monsterbaby..... yes a Tap like in a Tap & die, for cleaning up the threads of the main caps, its Sunday here in Australia & Im in slow brain mode, I was going to use a main girdle in the build but decided just to go with studs for now, maybe down the track if if i go more cam & compression i will certainly use a main girdle, Thanks.
Even then they hold together. I ran mine at 926hp shifting at 7600rpm, most of the time rev limited at 8000 and on more then one occasion took the rev chip out and turned it 8600rpm for 4yrs before I sold it to another kid. He has had it the past 3yrs and it's still running. I was using a 2 bolt main D9 block with ARP bolts in it.
77'FORD_man
04-17-2012 03:51 PM
AceCalibre
22
02-12-2011 01:57 PM
jamies460
07-28-2007 06:41 AM
jamies460
06-19-2007 08:44 AM
