C6 will not shift into park
I have a 71 F250 Camper Special, 390, and C6. I am at the tail end of a restoration. I rebuilt the engine but I didn’t do anything with the transmission. I had never had trouble with the transmission but it looks like I should have had it gone through while it was out anyway.
The truck won’t shift into park. I have completely removed the linkage from the transmission and still can’t get it to shift into park. It shifts through all gears and reverse with no problem. I have put a wrench on the shift lever (on side of transmission) an applied as much force as I dare but it still won’t move into park.
I only have about 30 miles on the truck and was putting new tires and rims on. I took around the block to try the ride on new wheels (I got on it enough to chirp the tires) when I pulled back up to the shop it would not shift into park.
Thanks for the responses
I have not swapped any transmission parts. The issue is that it wont quit pull into park (even with linkage off) it barley is able to catch reverse. I will get the pan off this weekend and take a look. even pulling the tail shaft wont be that bad. I just don't want to take the transmission out. I spent days sound proofing and installing new carpet in the damn thing. I think i would cut the cross member out from under it before I would remove the hump in the floor pan to get it out.
I only chirped the wheels a little. i am not sure what came over me; I just had to do it.
Thanks,
Thanks,
Thanks,
Thanks,
Hello Sam. This thread is over 4 years old so I would assume the OP won't answer you. I would suggest starting your own new thread with your particular details. What's wrong,work done related or not to your truck just before the problem came about,etc. We'll help ya!
That'd do it. Sounds like what you ought to do is go on YouTube. There are a bunch of them showing how to rebuild a C6. Scroll through one of them 'till he get to the parking pawl area. You'll then see how your's is supposed to be.
John
iron1951
02-18-2011 06:39 PM
Wayne Hamm
02-15-2005 07:07 PM
