C6 will not shift into park
I have a 71 F250 Camper Special, 390, and C6. I am at the tail end of a restoration. I rebuilt the engine but I didn’t do anything with the transmission. I had never had trouble with the transmission but it looks like I should have had it gone through while it was out anyway.
The truck won’t shift into park. I have completely removed the linkage from the transmission and still can’t get it to shift into park. It shifts through all gears and reverse with no problem. I have put a wrench on the shift lever (on side of transmission) an applied as much force as I dare but it still won’t move into park. I only have about 30 miles on the truck and was putting new tires and rims on. I took around the block to try the ride on new wheels (I got on it enough to chirp the tires) when I pulled back up to the shop it would not shift into park. |
I really need some help with this
I didn't get any responses to this transmission problem. Do any of you have any experience with this at all?
Thanks, |
Chad, It is not a common problem, and I suspect something is array inside the tranny case.
John :-X06 |
Take it out
an rebuild it you broke it went spinning new tread dude new gears need TLC till run in :-drink
Originally Posted by whitetrash
(Post 8685340)
Thanks for the responses
I have not swapped any transmission parts. The issue is that it wont quit pull into park (even with linkage off) it barley is able to catch reverse. I will get the pan off this weekend and take a look. even pulling the tail shaft wont be that bad. I just don't want to take the transmission out. I spent days sound proofing and installing new carpet in the damn thing. I think i would cut the cross member out from under it before I would remove the hump in the floor pan to get it out.
I only chirped the wheels a little. i am not sure what came over me; I just had to do it.:) Thanks, |
Chad if your truck originally had a 3spd the cross member is held in with rivets, unlike bolts for the auto.
Cut the rivets and replace them with bolts, and you can drop the C6 should you need to. John :-X06 |
(Post 8709450)
Originally Posted by Sam Alvarez
(Post 14600728)
I have a 1986 doing the same please let me know what u had to do thanks
Hello Sam. This thread is over 4 years old so I would assume the OP won't answer you. I would suggest starting your own new thread with your particular details. What's wrong,work done related or not to your truck just before the problem came about,etc. We'll help ya!:-X22 |
i have the same prob i think it happened when the neighbor pulled it out of the field where it was being stored without putting it in neutral got the valve body off ,got the tail shaft off it is in between the two.
Originally Posted by 69issofine
(Post 14704816)
(Post 14704816)
John :-X06 |
Originally Posted by jowilker
(Post 14705407)
Doesn't have to be in neutral, but would need to be out of park. Do you know if he took it out of park?
John :-X06 |
