96 F350 DRW ABS Light on
Old 03-24-2010, 02:10 PM
fsavage's Avatar
fsavage
fsavage is offline
Smile 96 F350 DRW ABS Light on
New to FTE but have had Ford Trucks for about 20 + years. My 96 F350 has the amber ABS light comes on and stays on after starting the truck. It was throwing flashing codes earlier that mean a memory failure. After looking around under the truck at the sensors a local mechanic recommended double checking all fuses. Sure enough one was blown and I replaced it. Now instead of the ABS light flashing it comes on and stays on. I would really appreciate any advice. Also can anyone recommend a good reasonable ABS code reader, I have a ECM reader but it doesn't read the ABS codes. Thanks.
Old 03-24-2010, 03:53 PM
Lazy K's Avatar
Lazy K
Lazy K is offline
Your truck, I would think, has RABS and not full ABS. So the light on means that the RABS computer has detected a fault and disabled the system. You will probably not notice any difference in braking as the RABS is not much good anyway.
However check the simple things first, check that the rear brake lights are working properly and check that the brake fluid level is good.
Can also be an idea to remove the sensor from the rear differential housing and clean it, then refit.
You do not need a code reader for the RABS. There is a diagnostic connector behind the glovebox that you ground momentarily and the dash light will blink out any error codes.
However try the simple checks first.
Old 05-27-2023, 01:18 PM
1974YEEYEE's Avatar
1974YEEYEE
1974YEEYEE is offline
4th Gear
Does any one know how to just dis able the lights for the abs
Old 05-27-2023, 06:00 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is offline
Received 1,365 Likes on 1,078 Posts
Why do you want to disable the ABS light in the dash? What code do you have? What have you done to address the problem and what vehicle are you working on?
Old 05-28-2023, 06:42 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,165 Likes on 920 Posts
Old 05-28-2023, 11:30 AM
1974YEEYEE's Avatar
1974YEEYEE
4th Gear
I’ve replaced the sensor pulled the fues put it back in and that didn’t work. The abs light only flashed once
Old 05-28-2023, 01:48 PM
My4Fordtrucks
What vehicle?
Old 05-28-2023, 03:11 PM
1974YEEYEE's Avatar
1974YEEYEE
4th Gear
1996 f350 7.3
Old 05-29-2023, 05:01 PM
rla2005's Avatar
rla2005
If you only got a single flash after momentarily grounding the test wire, the RABS controller is probably bad.
Old 05-30-2023, 02:37 AM
1974YEEYEE's Avatar
1974YEEYEE
4th Gear
Can I disconnect the controller and be fine or with it mess up anything
flywithjohn
15
06-09-2022 01:26 AM
hatchet
1978 - 1996 Big Bronco
16
12-25-2010 11:47 PM
speedyejl
1997-2006 Expedition & Navigator
04-21-2010 02:38 PM
Ohio Ford Farm
1983 - 2012 Ranger & B-Series
09-20-2009 08:30 PM
the4by4freek
1997 - 2003 F150
01-25-2004 04:43 PM
Quick Reply: 96 F350 DRW ABS Light on
