How to adjust the shift indicator??
So I went and replaced my instrument cluster lights and in the process of everything, i had to disconnect the shift selector (PRND21) frome the cluster. Well.... somehow during the corse of events when I put everything back together, i noticed that the selector is off by a gear. park shows as reverse, reverse as neutral and so on. the linkage to the trany is fine and everything works as it should. But how do i fix it so that when im in park it reads as being in park? Thanks for any help and the truck is a 97 4x4 extended cab with the 4.6 if that makes any difference.
hharris8
208
02-15-2017 10:56 AM
