Sponsored by: Real Truck
Transmission Range Selector Help
Old Nov 15, 2016 | 03:11 PM
koski19's Avatar
koski19
Last night the Shift Selector Tube broke on my 99 F250 SD.
I could not get the trans lever out of park. I went under the truck
and disconnected the shift cable from the manual selector. With the help of a friend holding the brakes and park brake, I went under the truck and moving the manual selector, found reverse then backed the truck out. I then found drive and brought the truck home. Today, I bought and replaced the broken shift selector tube. Here's the problem....I'm having difficulty finding Park and Neutral. I found neutral, started the truck, found reverse, and drive but when I put the lever back to park and shut the engine off, it won't restart. I need to find neutral again. I didn't move the range sensor, just the manual lever.
How do I make things right again and to find and have park, reverse, neutral and drive.
Thanks in advance.
Old Nov 19, 2016 | 09:35 AM
koski19's Avatar
koski19
Figured it out. Got it fixed.......Thanks for the help......Appreciated......
Old Nov 19, 2016 | 01:33 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
So since no body knew the answer, maybe you could share it?
Arizona 95 F250 XLT
Dec 10, 2024 05:35 PM
birdboy
Mar 18, 2016 10:49 AM
Walwal44
Feb 2, 2015 05:12 AM
chevyhater74
1983 - 2012 Ranger & B-Series
May 28, 2005 01:46 PM
infoguy
Jul 11, 2004 10:26 PM
