1959 Parking Brake
Old 02-07-2010, 09:53 AM
KillerTux's Avatar
KillerTux
KillerTux is offline
1959 Parking Brake
I just picked up a 59 F100 and I can't figure out how to use the parking brake. It does not say in the manual and I couldn't figure it out by moving the handle.
Old 02-07-2010, 10:51 AM
Old F1's Avatar
Old F1
Old F1 is online now
Welcome!
Does the handle have a release part, a button or portion that you push or squeeze? There is a really good chance that the handle, the release, the cables, and everything else in the emergency brake system are rusted and seized together. Maybe start by disconnecting the cable at the handle and see if the handle moves, and beyond if necessary.
Old 02-07-2010, 04:48 PM
vbarker's Avatar
vbarker
vbarker is offline
The 58/59 e-brake handle pulls straight out. To release it you turn it to the left (I think) and push it back in. If you don't feel any pressure as you pull it out or the rear brakes don't seem like they lock up, then you may have a cable broke or disconnected from the rear drums, or the rear brake pads may be wore so bad they aren't seizing the drum. I'm not sure you can remove the cable from the handle at the dash. I will have to ook at mine this week to verify.
Vern
KillerTux
08-13-2011 11:01 PM
Derrick lane
25
12-08-2010 04:56 PM
Headviking
03-30-2010 06:49 PM
Falcon731
06-08-2009 12:42 PM
mustange70
11-22-2004 04:47 PM
Quick Reply: 1959 Parking Brake
