3ON TREE -AUTO CONVERSION
Old Feb 6, 2010 | 11:33 PM
woodyf1's Avatar
woodyf1
ANYONE EVER CONVERT THE COLOUM SHIFT TO THE AUTO ON THE COLUMN i WILL TRY TO FIGURE IT OUT I DONT THINK IT WILL BE THAT HARD .... ANY IDEAS
Old Feb 6, 2010 | 11:45 PM
Julies Cool F1's Avatar
Julies Cool F1
Yep, it's easy. You just use the top shifter and run a shifting rod down to the lever on the Automatic Transmission.
You can pull up your steering column floor plates, remove the clutch pedal pad and spring and drop theclutch pedal below the floor. I used a nylon tie to affix the clutch pedal to the lower shift lever on the column.
Thus when you pull up on the shift handle, the shift rod pulls up setting the pin in the top shift lever and when yo upull down it clicks through the gears. You can actually feel and har it shifting into the gears as you move the lever.
I think we talked about this before and we saved the link. Here it is:
https://www.ford-trucks.com/forums/8...to-column.html
If you need any pictures or more info, feel free to let me know.
Old Feb 7, 2010 | 01:43 AM
wheelie31's Avatar
wheelie31
who would dare butcher a perfectly good manual trans truck with a Darn automatic! ha
Old Feb 7, 2010 | 12:20 PM
woodyf1's Avatar
woodyf1
you think the stock manual was perfectly good????probably bullet proof but not good at highway speeds wrong ratio
Old Feb 7, 2010 | 12:41 PM
52 Merc's Avatar
52 Merc
Unless you're adding overdrive with your automatic, a trans swap won't change the final drive ratio, since high gear will still be 1:1.
Old Feb 7, 2010 | 12:47 PM
woodyf1's Avatar
woodyf1
My apologies I forgot to mention that I am installing an aod trans
Old Feb 7, 2010 | 05:14 PM
Julies Cool F1
Nice combination!
I was able to add about 8 to 10 miles per hour at freeway RPM just by putting larger tires on the back too. It negated my plans to use a US Gear 20% overdrive - cruises perfect now (C6 1:1/2.80 rear/235/75R15s - 2300rpm @ 70 mph)
Soooooo Woody? When is the "Maiden Voyage?"
